  • Replies 6k
Posted Images
we just got home from my brother-in-laws 30th Birthday lunch at the Port Adelaide Footy Club .... mmmm belly full of potato and leek soup, beef schnitzel and pavlova ;)
Took these photos when we got home - crazy hail started just as we neared home and continued for around 10 minutes!
im been forum surfing and found so many interesting motor vehicles and conversions.
how this for a change, a is200 with a 2jz conversion. damn!!
amm....
i want it so badly for 2 years! :hearts:
i tell myself i will build one of those after i get my residency
But seems it will never happen :Oops:
amm....
yeah its a quite impressive conversion, looks factory almost.
i stumbled across this, aint a conversion but very nice from drifting.com. Those who are into drift would know that this is chris forsberg's old? drift weapon.
widebody fd
of all things it was to be powered by a sr20 due to its avaliability and aftermarket components. Dont know what eventually went into it....
before widebody kit pics of the FD
looks to me like it was a cheap imported rally car stripped to be drifted.
They also have a s15 drift dedicated companion to the FD.
