  • Replies 6k
Posted Images
how is everyone? I finished at 1pm today, so am spending the rest of the day at home in fornt of the PC/TV avoiding the rain :)
We have Foxtel IQ - has a 160Gb Hard drive to record your favourite shows on. Watching Underworld at the moment ;)
