  • Replies 6k
Posted Images
ill be taking it easy for a bit, while im running the engine in anyways. what steps did you follow to run your engine in cubes?
Quite contentious, can't say whether I'd follow this advice or not, but it's certainly food for thought. http://www.mototuneusa.com/break_in_secrets.htm
And on a totally unrelated note here's some pictures...
:D
interesting stuff hey. they say if you dont run the engine hard the rings wont bed in properly. i suppose motorcycle engines would have to be similar to the running in of a car engine. coincidentaly the pistons ill be using are CP forged ones, and they make the majority of there parts to suit motorcycles.
Sambo33,
I was conservative and hung off before taking the jump to synthetic.
I used Penrite run-in oil for the first 1500km's, did 3 oil and filter changes.
One after a couple hundred then the other 2 every 600-700 or so.
I then ran Motul Motion 10w30 Mineral oil until the motor clocked up 10,000km's.
Within the 8500km's I did 2 oil changes, each at ~4000-5000km's.
I then went to Motul 8100 X-cess 5w40.
With regards to how the car was driven, I wired open the wastegate so I could get plenty of load on the motor without boost flicking up to 10psi and creating to much load.
The car went on the dyno to check afr's and ignition timing, I rev'd it to 3500rpm and drove with a flat foot everywhere for the first ~1000km's.
After that I began to rev it a little more ~5000rpm.
I only had it tuned and boost hooked back up once i got synthetic and the PFC in to the car which was at 10,000km's.
So it had lots and lots of time for the rings to bed in and properly as I could get a nice amount of load in to her.
Even though I'm running the largest recommended bore to piston clearance for 24+psi and race use it uses zero oil and has no oil in the intake piping.
It did use a little oil and had oil in the intake piping up until around 1,500km's.
It has slight piston slap on cold starts but goes away very quickly. :D
I was told by the engine builder not to jump in to synthetic too quickly as by doing so can only cause harm, not doing so won't cause any harm but only potentially good.
I've bought a few bits in the past week or so, GTR injectors (good for ~270rwkw on std fuel pressure) and a vg30det turbo that I have the exhaust housing machined up to suit a GT30 600hp CHRA and .7 comp cover. :D
I've attached a map trace for those that are fiddlers like myself.
Its also time for another oil change.
I've decided to go with the heavier Castrol 10w60 over the Motul 8100 5w40.
I went a K&N Oil filter over the PureOne this time as i'm tired of skinning my knuckles trying to remove the old sucker. :cheers:
My other half thinks its sad taking pictures of oil ($59.95 @ Autobarn) and a filter ($18.95 @ Sprint Autoparts).
Whats worse is for some reason I get excited when I look at my new oil filter and castrol oil :)
Whats worse is for some reason I get excited when I look at my new oil filter and castrol oil :wave:
They just don't understand.... Do they! How much better is ya car just after a oil change, which reminds me I'm just about due too!!
Oil change.. :wave:
Feels the same to be honest, it didn't use a drop of oil and there was no nasty's in either the filter or the bottom of the drain pan.
I want to get myself one of those cheap oil cooler and filter relocation kits for $175, then grab myself an elec. oil temp and pressure guage and mount it in the center console where the GTR's have their three guages. So many plans, so little money. :D
where can you get the oil cooler and filter kit for $175 i woudl like to know. cheapest ive seen is $350 complete kit.
Sorry $350. lol
http://www.skylinesaustralia.com/forums/sh...ead.php?t=81255
I had just finished looking at the IC for $175. :rofl:
Oil change.. :rofl:
Feels the same to be honest.
i got a Earl's oil cooler coming on early August which i don't need now... crazy1.gif
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
