i dont think it would be that hard unless you would rather pay someone else to do it. i painted my calipers myself - piece of cake, and have painted the front of my sil80 myself which sam though was resonable ok - well the one that i though didnt need attention which i was quite happy coming from a spray painter himself.
  • Replies 6k
Posted Images
Be sure to spray the car when it's not cold. :D
or. Hire a heater. :rolleyes:
ive already done that mate. hired a heater and compressor.
i successfully sprayed one front panel and front bar but felt that the others were not how i would have liked it to be. thus why im asking someone if i could borrow a compressor for a few days or else i would have to donate that money to kenndards and the likes. plus now i have a gravity feed spray gun whereas i had a siphon one before. would make life easier since i can now spray bodykits at home, yiipeee.
you're welcome to borrow mine Duc - I just had a look at it - it is only a dodgy el cheapo GMC one, but is brand new - I haven't even fired it up yet.
1500W 2Hp
tank capacity 24L
206L/min tank displacement
117l/min free air displacement
0.8MPa max pressure
these numbers mean nothing to me - maybe they do to you?
thanks andrew much appreciated. they dont mean nothing to me either only the cfm matters, ill ask sam if its sufficient. Again, thanks andrew ill take you up on the offer hopefully. btw why havent u used it yet, impluse buy??
hey duc, when u planning on repainting the silvia panels?
hopefully at the end of this week pending weather. Got some installs/maintenance to do as well so yeah. btw andrew has posted up a list of spec on his air compressor, you thinks thats suffiecent sam or do you need to see it to look at cfm - would give us an excuse to see andrew's car also. =D
you in adelaide/murray atm?
24L tank is a bit too small, you would find yourself constantly running out of air pressure. you would really want a minimum of 50L tank and 3.0HP, to keep air pressure consistantly above 3.0 bar. what spec was the last compressor you borrowed?
im back in murray bridge atm, i help my dad out with his hospital appointment.
i honestly cant remember but just know that it was 12 cfm electric compressor. i think it was 3hp. A wells im just gonna have to hire another one i guess since its my last resort. Just bought rego the other day and its begging to be driven =D coming back to adelaide anytime soon?
i'll probably be back in adelaide this weekend.
you headed to mallala this weekend?
i hope the weather is going to be at least not raining this weekend. Thinking bout touching up the paint on saturday and drifts sunday. I might give the rally a miss this year. well, thats my intentions anyways.
im keen on going to mallala, ill let you know. yeah, hopefully the weather will be like last sunday. im heading down to adelaide tomorrow, more carport work to do :( have you sorted the air-compressor out?
i havent had the chance to sort out the compressor as yet. Probarbly go and look at some today @ kennards or usual place i hired it last time from. Having said that, im not sure if im going to get it though because if its raining on the weekend then theirs no point to it.
Has shaun got the block/heads etc back yet so your car can be put together?
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
