i dont think it would be that hard unless you would rather pay someone else to do it. i painted my calipers myself - piece of cake, and have painted the front of my sil80 myself which sam though was resonable ok - well the one that i though didnt need attention which i was quite happy coming from a spray painter himself.
  • Replies 6k
Posted Images
Be sure to spray the car when it's not cold. :D
or. Hire a heater. :rolleyes:
ive already done that mate. hired a heater and compressor.
i successfully sprayed one front panel and front bar but felt that the others were not how i would have liked it to be. thus why im asking someone if i could borrow a compressor for a few days or else i would have to donate that money to kenndards and the likes. plus now i have a gravity feed spray gun whereas i had a siphon one before. would make life easier since i can now spray bodykits at home, yiipeee.
you're welcome to borrow mine Duc - I just had a look at it - it is only a dodgy el cheapo GMC one, but is brand new - I haven't even fired it up yet.
1500W 2Hp
tank capacity 24L
206L/min tank displacement
117l/min free air displacement
0.8MPa max pressure
these numbers mean nothing to me - maybe they do to you?
thanks andrew much appreciated. they dont mean nothing to me either only the cfm matters, ill ask sam if its sufficient. Again, thanks andrew ill take you up on the offer hopefully. btw why havent u used it yet, impluse buy??
hey duc, when u planning on repainting the silvia panels?
hopefully at the end of this week pending weather. Got some installs/maintenance to do as well so yeah. btw andrew has posted up a list of spec on his air compressor, you thinks thats suffiecent sam or do you need to see it to look at cfm - would give us an excuse to see andrew's car also. =D
you in adelaide/murray atm?
24L tank is a bit too small, you would find yourself constantly running out of air pressure. you would really want a minimum of 50L tank and 3.0HP, to keep air pressure consistantly above 3.0 bar. what spec was the last compressor you borrowed?
im back in murray bridge atm, i help my dad out with his hospital appointment.
i honestly cant remember but just know that it was 12 cfm electric compressor. i think it was 3hp. A wells im just gonna have to hire another one i guess since its my last resort. Just bought rego the other day and its begging to be driven =D coming back to adelaide anytime soon?
i'll probably be back in adelaide this weekend.
you headed to mallala this weekend?
i hope the weather is going to be at least not raining this weekend. Thinking bout touching up the paint on saturday and drifts sunday. I might give the rally a miss this year. well, thats my intentions anyways.
im keen on going to mallala, ill let you know. yeah, hopefully the weather will be like last sunday. im heading down to adelaide tomorrow, more carport work to do :( have you sorted the air-compressor out?
i havent had the chance to sort out the compressor as yet. Probarbly go and look at some today @ kennards or usual place i hired it last time from. Having said that, im not sure if im going to get it though because if its raining on the weekend then theirs no point to it.
Has shaun got the block/heads etc back yet so your car can be put together?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
