  • Replies 6k
Posted Images
ahh so you think i may need a fuel pump??? i need a few other thing done also so i will check them both out.
i wuold say if you have the money, definately get it done when the PFC is installed.
Hey Sam i'm a Official at Classic Adelaide this year. I registered to be a Course Car, well drive mine as a course car, but unfortunaly i was too late and they have them sorted, so now i'm gonna be in a WRX, which should be a bit of alright!!!! They said Next year as a definate for my car! SAWEEEEET
nice one. it wouldnt be everyday you get given a WRX to drive :P
sup ladies, how are we tonight?
i just dl'd a 50min vid of something along the lines of getaway in stockholm but instead of cars, a go-kart is used. looks pretty good. (darren you might like it since your into carts)
thats all for now......later yoll!!!
Yeh PHAT, nice work on the pick up Duc. The engine on the Kart sounds like it's a 125cc Rotax engine, as they say it can reach upto and over(depending on the single gear used) 160km/h. This is the engine my mate uses for his Superkart(your right there Sam) but can be used in a Sprint Kart. Down the back straight of Mallala my mate has reached high 160's nearly 170km/h, at only 30mm off the ground.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
