  • Replies 6k
Posted Images
i looked down my driveway and what do i see...a nice stream of green liquid! yayyy new water pump! no car for the weekend...mechanic said $300 to fix it. dam these thing always happen on fridays so u dont have the car all weekend. :)
I would be very happy with it only being $300 to fix.
Its quite a big job replacing the waterpumps on these RB's.
You require coolant... The water pump, there's almost $150 in parts.
Then you have to remove the radiator, all fan belts, harmonic balancer, timing belt, remove the water pump replace it then all those bits go back on again. $300 is a very good price and who ever it is is definitely looking after you. :)
anyone know the legalities of driving on prescription narcotics? :P ie insurance, police/courts, etc
on Endone now for a while..... man it makes a huge difference to the knee pain, its amazing :P whats more it aint giving off the fuzzy-head pill-syndrome,so thats good.
oi - how about this damn avatar???!! wicked, found it on ebay
got a drive in a SRT8 Jeep. Its only slightly slower than the Porsche Cayenne Turbo S. It does a 5.1 0-100, not bad for a 2 tone car :) It's now the fastest car that we sell, Its even faster that the lighter 300C SRT8
When you put your foot down there is no wheel spin it just launches off and get really fast quickly. And it sounds fantastic with its standard 3" twin exhausts
But then again for 85K you can get a fast GTR that doesn't need to be refuelled every few Km's
You tube have a few decent vids of the SRT8 Jeep.
Interesting... They appear to be running High 13's. :S
Unsure if they are stock, sounds stock. Apparently the ecu also limits throttle until a few kays have been pushed up on it.. Not sure how true that is.
lol...
I came across a snip from a bathurst vid I chopped 2years or so ago.
Awesome little clip this... Pure Power down the straight.
http://videos.streetfire.net/search/Skylin...63462250d20.htm
Whatever that chasing car was, it got owned yours truely!
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
