  • Replies 6k
Posted Images
LOL !!
I heard Greenline were better, cheaper shipping etc. hahah, anyways got the kneecap in a jar at home, so I can unzip the leg and whack it back in (like false teeth) as I see fit... NOT.
Yeah, a tad sore now. Pill'd up but rather not take those mindbending painkillers (certainly not at work anyways). Meh. And I was going so well with the physio as well, had increased the strength of the muscles around the right knee area by over 40%.
Simply lifted left leg up and lunged to stop a ball that was kicked to me, and the weight transfer and angle on the bad leg just caused it to horribly collapse in on top of itself. Meh, I'll get used to it. Apparently its partnparcel of not having the kneecap.
LOL !!
Dude.... I got coolant poisoning from some Castrol Radi-cool at the moment and the part about no kneecap and the thought of the pain you have to go through really is making me consider inducing vomiting cause I feel like ultra-shit now. I woke up last night at 4am to find my mouth completely numb then when I read the bottle it said I shouldnt drink it? WTF? lol...
lmao.. sorry I had to laugh.
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :D
How you ended up drinking coolant.. lol do tell us. :(
I can't remember the last time I owned a brush/comb!
:P:nuke:
my leg collapsed in on itself 2 days ago.
so sad
so PAINFUL gggrrrrrrr
tibia went out and femur came in (no kneecap), fullon collpsed into itself
ouchies
:O
:D FAR OUT!!!!
Sounds horrible hope myou are ok and get better soon
By the way I have arrived in Adelaide today :(
:P:nuke:
:D FAR OUT!!!!
cheers man, hope you enjoy wetnwindy lil'ol Adelaide, today is normal - it always rains here
I haven't brushed my hair for a good..... 8yrs I'd say.
Shaved head. :(
Shaved head is cool
I know all about Adelaide use to live here that why I moved to sydney lol
Jess
I've had coolant in my mouth before and the taste is unbelievably horrible. Nothing I did got rid of the taste that hung around all day. :nuke:
Long story short, water cooled pc, curiosity, fumes in my room, numb mouth at 4am in the morning, thought I was gonna die. (I had to syphon the shit out of my tubes).
Edited by Pauly33GTS-t
welcome Jess
sorry to hear about your knee Brendan ... were u on pain killers when u put all the thermal paste on the CPU :D
Yeh always puts on a great show for visitors!
YAY!!!
The regulars are here :nuke:
Yeah im used to crappy weather especially when we come to visit :( but will still have fun :P
Hopefully I can wish the rain away :sorcerer:
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
