  • Replies 6k
Posted Images
this weekend im not doing anything, just 2 pro evo nights, 1 tonight and a bigger one tomorrow night.
Next weekend I'll be having a big mother f**ker, ill give you my number and well catch up then.
No I dont think its going to shit, there is nothing wrong with it at all. People shouldn't just attack people like you do dan, or that black32 im so cool guy.
You didnt tell me about the hose already all you said was the stuff you have doesnt fit and I doubt they make the OCC hose big enough to fit over those ports so I am going to have to go and get soemthing that will.
Paully.....
I will say it again the hose i have at my home came off the rex.....its too small.
Now like i said before i dont have that little breather hose on mine i have oil catch can hose on both breathers. So yes they do make it that big. Go to autobarn would you like there number and address. If you like i will go and take a photo just to make sure you understand that yes they do make it and yes it does fit just not the old hose i have off the rex.
dan you misunderstand completely. and no i have been told generic hose from those places wont be good for the breather as oil braeks down the inside of the hose. depending on what people have ill ask.
The heater hose stuff works perfectly fine for quite a bit longer than you would expect. I've had some on mine for a good 2.5years now; yes it has recently started to feel a little soft but its not stuffed just yet. :thumbsup:
Look in the sticky misc workshop listing as there's a few rubber places listed in there that sell the 'correct' stuff that you are after.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
