Hey All,
Well. santa was good enough to spot me some wheels, and i don't have room in the shed for a spare set so these need to go.
They are Volk Racing Emu's in 17 x 8 & 9's (from memory) They are all in good nick apart from the odd gutter kiss. I can't remember the offset's but the attached pic shows them on stock r33 guards with no spacers etc. If you really need to know i'll pull them off and check. Tyres are good with about 80% left. Fronts are good year potenza's 215's and rears are Ventus Sports 255's.
Rims are multi nissan stud ie 4 & 5 stud patterns.
Let me know if you need more info.
1650 ono 1300ono.
post-3771-1167124409.jpgpost-3771-1167124430.jpgpost-3771-1167124481.jpgpost-3771-1167124514.jpgpost-3771-1167124534.jpgpost-5157-1129130646.jpgpost-3771-1167124765.jpg
Edited by DRAGTS
https://www.sau.com.au/forums/topic/148755-volk-racing-wheels-price-drop/
Hey guys, i have it on good advice that offsets are +38 front and +40 Rear. But again if your serioius i'll pull them off and check. New wheels should arrive in 2 weeks, so i'll check then anyways.
Price Drop.....$1500. Come git em!!
Edited by DRAGTS
  • 3 weeks later...
  • 1 month later...
  • 3 weeks later...
hey man, i got cash now again lol.... but ive only got 1000, will you hand these off for about 1000? if u still got em that is and i'll be ready for pick up on wednesday or thursday or friday
yeah i still have em, but i've had an offer of 1200. Told him if no one else beat him by Sunday, they're sold....
Just go and sell your body for the night, that'll land you some extra $$$ LOL!!
Edited by DRAGTS
  • 3 weeks later...
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
