so after many year of waiting, i finally got my r33 gts-t last week. It had a really nice body kit as well as some performance mods and was in great nick. The owner warned me about driveways and just said be careful cause its low.
So after less than a week of driving, being super careful around driveways and speed bumps, i get back to work today after holidays (which has an undercover carpark). I drive into the drive way no problems and drive down the hill, open the gate then slowly creep down the hill thinking it should be ok. next thing i know, *crack*. front bar has copped a nasty knock. back out and take a look.. its a nasty-ish crack with some surrounding paint chipped of the front bar as well. I read the home-repair thread but i think this one might be a little out of my ability. Its not like the bar is hanging off or anything, but the crack is pretty bad and its chipped away a fair bit of the paint.
I checked the 'queensland workshops' thread but it only had 1 panel beater listed, and that was in brisbane. My questions are:
1) can any panel beater fix this up or does it need to be a bodykit specialist or something ?
2) what sort of price range am a looking at. Its going to need more than just a respray, some fibreglass will need to be replaced and stuff, but its not like they have to go over the whole bar fixing it.
3) anyone have any recommendations of places which will do a good job that are on the Gold Coast. the only one that someone has said to me so far is burliegh smash repairs with a warning that they do a good job but are a bit pricey.
Edited by Strik3r
https://www.sau.com.au/forums/topic/148824-my-first-crack/
that is too bad. i've had a fibreglass front bar for about 6 months now, scraped it on driveways, had a fury animal run out in front of me and all i have is 5 little cracks. the longest one about 3 inches.
any panel beater should be able to do it.
https://www.sau.com.au/forums/topic/148824-my-first-crack/#findComment-2775657
Pulled into a repair shop i saw while driving to get my stereo installed and got a quote for $250.. i'll check out a couple of others.. I'd take it to the recommended places, but by the time i drive there and back i'd be paying $30 in fuel so might as well get it done locally. Its not a horrendous crack, but it does detract from the look of the car. I'll play it a bit by ear.. i should probably wait another month or 2 until ive really gotten used to where I can and cant take the car before i get it fixed up, but then im pretty obsessive/compulsive about things being neat and tidy, so i dont know if ill put up with it for that long :P
thanks for the replies.
https://www.sau.com.au/forums/topic/148824-my-first-crack/#findComment-2777103
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
