Never personally owned them, but Ive driven a couple S13's with them.
IMHO get the GREDDY coilovers, theyre only about $300 more, have more adjustment and feel like a more refined package.
That is how I felt about them, with HSD's in a 180 type X and a S13 silvia, and the greddy's in a S13 silvia
https://www.sau.com.au/forums/topic/148886-hsd-coilovers/#findComment-2776985
Personally I hate them. I borrowed them off a mate cos he had em out to go through regency and I was waiting for new coilovers cos mine were blown. There wasn't too much difference between by blown Tanabes and the HSDs. This has been my experience with them anyway.
Shocks are something that require a lot of R&D and you just cant do this when selling a full set of coilovers for bugger all.
I would recommend Sydneykid's groupbuy once the shocks come back into stock. The ride is so so comfortable and handling is really good.
To quote Sydneykid himself
I did this for a magazine article some time ago, the editor hated it because it showed a lot of his advertisers in a bad light. The idea was to take a $1600 coil over kit (not for a Skyline) and break its retail price content down to show what you get for your $400 spent on each corner. Then compare it to a Bilstein, Koni, Whiteline, Kings, combination for $400 per corner
Coil over kit retail price breakdown;
Strut top $60
Bump stop $15
Dust cover $8
Upper spring seat $20
Lower spring seat $15
Threaded sleave/case $30
Spring $80
Shock $172
Total $400
Bilstein, Koni, Whiteline, Kings;
Bump stop $15
Dust cover $8
Spring $80
Shock $297
Total $400
It's easy to see that you get a 75% superior shock value ($172 compared to $297). The cost in a shock is the type of materials used (fairly minor difference) and the valving sophistication (where the real money is spent).
https://www.sau.com.au/forums/topic/148886-hsd-coilovers/#findComment-2777259
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
