These injectors, are they made by Deatchwerks? is it lik saying im installing nismo injectors, instead im installing Deatchwerks injectors? has anyone used them? what are they lik? cos i lik the price.......
I have these injectors.. works fine for me. i have 240rwkw and max duty cycle i seen is 68%
i highly recommend them, they are high flowed injectors.
They are straight fit.. just like nismo.. fit on stock fuel rail, and comes with flow report of each injector.
Alot of Drag supra's in the states use them
check out their website..
http://www.deatschwerks.com/
Also if you do a search on deatschwerks on any car forum, people seem to say good things about them..
just stay away from Venom injectors.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780025
What size injectors do u have? Im aming at 250kw at the wheels
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780033
only had them in for a couple of months. no problems with them so far.
My tuner said he really liked them.
It was about $600 delivered.
you can also get some cashback offer too if you send your old injectors to Deathscwerks so it works out to be even cheaper.. i didn't do this though as i damaged the old injectors trying to pull them off the rail.. haha
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780057
ok cool was jus wondering how long they will last for. How long do injectors useally last for
Haha damn, i might be careful taking mine off then haha.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780062
I can't see why they would not last, my stock injectors were fine ( well not after i pulled them out) and i had about 180,000km on the clock.
Just keep an eye on max duty cycle on your PFC controller.
Bear in mind that it will show overall injector duty cycle not individual.
They flow test the injectors thoroughly and my injectors had something like 0.02% variance. Each injector is marked with a number which corresponds to the report.
yeah careful taking out your old ones, you can even pack them in the box that your new injectors came in and send them back to them.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780074
excellent thanks for that, good info. cheers
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780078
i'm in.... I'll give them ago
Cheers
So a guess mods rather than rebuild?
I went the mods route.
I got a fair few kms on my car.didn't know if i should sell it or mod it. took it to my tuner and he put the car on the dyno did som test on it and he said everything is healthy and if he was me he would keep the car.
i said i'm worried about the kms on the car and if i mod it something mite go wrong.. he said kms aren't everything you can have a 60,000km car with a bad motor and have a 200,000km car with a much more healthy engine. then i asked him if i should do rebuild first before modding it.. and he said what for? as long as the tune is good and safe you shouldn't have any problems.. alot comes down to the tune.
If you aren't chasing that much power then no need to rebuild what could be a very healthy engine.
anyway just my thoughts.
good luck with your decision.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780298
I'm no guru but it seems u can make good power with a rb25 motor in good condition without the need for new internals..I have been running 250+ for some time with stock internals...I did a compression test recently cos I was bored and everything was the roughly the same as when I got it tested 1 year ago before the mods...
verdict...its ok.
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780553
Hey mate what state u in?
Also what time frame are u looking at doing this over?
I'm in vic mate you? thinking anytime from now untill late jan early feb!
they sound like a good deal..
Edited by RPR33
https://www.sau.com.au/forums/topic/148987-6k/page/2/#findComment-2780857
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
