Im selling my beast Gtr 32 gun metal grey now $39500 with everything, the engine build from japan and the car only use it 3-4 times a month. Any question can just pm me about the car. engine done lest then 15000k, the car now is 80000k on the clock. The oil change every 2000-3000k everytime, car is in good condition and last dyno readout was 479HP @ rear wheels running 16PSI boost. Turbos are good for at least 2 bar so very impresive HP can be achieved if you want, can capable for 600+hp. Can removed parts for lower price. Serious buyer only...
Gtr 34 N1 Block
N1 bottom end
N1 oversize pistons
N1 Conrods
N1 Crank
APEXi cams - 270deg inlet
- 270deg ex
Nismo metal head gasket
Twin TD05/06 high mount turbos
ported and polished head
OsGiken Triple Plate Clutch
TRUST Manifold
TRUST intercooler
TRUST high volume sump
TRUST exhaust
TRUST front pipe
TRUST external wastegate
Custom Stainless steel turbo pipes
Arc oil catch can
SARD 800cc injectors
Greddy oil cooler
Fuel Regulator HKS
TEIN adjustable suspension
HKS turbo timer (wired into imobiliser and remote central locking)
HKS boost controller
APEXi POWER FC D-Jetro with hand held commander
CUSCO front and rear strut braces
Nismo dash
Nismo steering wheel
Greddy oil temp guage
Greddy coolant temp guage
Greddy exhaust temp guage
GREX shift knob
Nismo front bar
Tinted windows
HKS adjustable timing gears
Nismo timing belt
4 Defi gauges, intake manifold pressure, boost, oil press, water temp {New}
19x 10 Work Meister with Hankook Tyres K104 {New}
Pioneer tv
Location Perth >_<
Edited by Hoshima
https://www.sau.com.au/forums/topic/149064-fs-1990-gtr-with-gtr34-n1-engine/
Mmmm... anyone interested. Need to sale fast because going to go back to oversea. Make me a offer with reasonable price, i may think about it.....
Got Dyno sheets for the 479hp? Who tunes it here in Perth? What model Tein suspension is it? Got receipts for all the internal parts that can't be easily checked?
Engine bay and interior pics please.
Cheers
Brett
Hyperdrive did the all the work, yes got the dyno shit for it as well. Yes i got all the receipt with all the details of the engine that most of them already translate in english.
Edited by Hoshima
Alright Hosh, time to set things straight, are the followoing comments true ???
1. The gear box in your GTR currently has no third gear as it is stuffed.
2. Your engine compresson is all over the place, with as low as 90psi in one cylinder.
3. There are no receipts that can verify that the engine is newly built to N1 specs or is even new at all. IF so how do you xplain the cylinder pressures???
Just what I hear around the rumour mill, and not a reflection on you personally. But you wouldn't wan't to sell a lemon to a fellow SAU member would you ???
I did tell everyone who are serious about the car if theres anything wrong with it. As for the gearbox is going to be replace when i sale the car, as the compression test , yes one is low 90-95. the rest is fine and is not all over the place. The engine is still good condition because they know when i take them for a drive, the installation engine did by hyperdrive beginning last yr and other mechanic already verify the engine is n1 spec. I got the receipt with all the details of the engine.
The price im asking i know is cheap already, if they not happy their dunt buy it as simple as that. I already got alot of interest, the car is already sold pending, is just waiting for the guy to organice the rest of the money after he sale the car so dunt waste my time with this.
Edited by Hoshima
So,
Seriously would you concider selling with out stereo, rims.
And taking the misc feedback about the engine, sounds like it needs a bit of attention.
and the gearbox...
What is a price your willing to??
Cheers
Pm me with some info
thanks
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
