I have a whole bag full of LED parkers at home (white) ... if anyone needs some, shoot me a PM :laugh:
I might be interested...the yellow looks shocking .
Could you take a pic of yours so we can see what they look like switched on?
LOL ok guys... I'll get my mate to put two in tomorrow and get some pics at night. Currently I'm using "white" bulbs which aren't anywhere near the colour "white" compared to my xenons.
Anyways, I estimate that there would be about 20-30 in the bag so no shortage there :D
looks to solve the yellow parker white headlight problem...i've only got normal headlight globes, not blue light or anything like that, but the difference between the parker and headlight looks shocking
How much you after for a pair? I might grab a couple of sets
Here are the pictures of mine after I have changed it..
The colour is very white.. but the downside is that it's maybe 30-40% of the former brightness.. but those with HID most probably won't care.. and I'll be having a HID conversion as soon as I get the money for it.. damn accident costing too much..
cheers to satanic for sending me another one after 1 of the led dropped into where the parker sits.. :D
no way of getting it out.. so shout out to you mate!! you rock =) he even posted it out!!
hahah I dropped mine in there too! I rekin if I can be bothered taking the whole headlight out, i'll be able to shake it around till it falls out...
Installed mine...they're whiter than my headlights....so I'm gonna have to get some whiter headlight globes lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
