Brendan , unless you are going to constantly drag race the thing , go with Autoclutch and there 9 plate sprung brass button with slightly upgraded pressure plate.
Have fitted it to 3 x GTR's and 1 300ZXTT with no prob.
Micko , rhino and Boosted RB26 have them in there GTR's and Rhino did a 12.4 with his from an off the limiter launch.
Price for BoostedRB26 last week was $800 ish fitted and took one day.
Twin plates are good but rebuilds are expensive .
Cheers
Ken
I have a nismo twin plate and it's fine to drive. Before that i had a 5 puck ceramic single and it wasn't any different to drive. Both weren't very easy to drive but were quite manageable on daily basis.
My advice would be to go for a twin plate, your wife will get used to it. It will be a pain for her compared to other cars she may drive, but unless you put back in an organic-full faced stock clutch in there, all others will be as well.
Thanks Emre, I must also point out that once the engine has been rebuilt it will easily be putting out over 350rwhp considering it put down 302rwhp at only 0.75 bar but was running out of air and fuel (now solved with purchase of 660cc injectors and z32 afms). Would a rebuilt standard be able to handle this sort of power and more knowing I will be taking it down to the drags once in a blue moon.
Cheers
Brendan
You should have no problems if it's done properly to the factory specifications or better. 350 hp at the wheels is well within limits of the stock bottom end.
To answer your previous question, if you go for a twin plate a lightened flywheel will come with it, do not lighten that any further. If you decide to go for a single plate you can choose to lighten and balance your factory flywheel, just don't take any more than %25 out.
In fact, re-reading your last couple of post i would urge you to go for the twin plate. For a single plate clutch to hold onto 350hp+ it would have to have a lot less surface area and a very heavy(on the foot) pressure plate unless the pivot point of the fork is altered. Result would be a no more friendly setup than a twin plate that can handle 700hp at the flywheel.
A lightened flywheel will help you accelerate quicker. The mass of a twin plate assembly is naturally more than a single plate, so they compensate it with a lightened flywheel already. In my case, it was still slightly lighter than my single plate setup.
Originally posted by rb26dett
hey VspecV just wanna know, did ur hks clutch feel soft at all? mine's really soft...and i mean soft....
the stock clutch was much heavier than this one, but the bite in this clutch is mad....no slip as yet...
i fitted a hks twin in a r33gtr yesterday and its very soft and take up is very close to the floor
my take up is pretty far off the ground, but i understand that this is adjustable?? correct me if i'm wrong...
1st time i tried it i was like...wat's wrong it's so soft...then it wheelspinned n stalled n i was like...oh my...wrong clutch choice..
Well ladies and gents, we've made a decision on what clutch we're going with. Thanks to Paul and Brett for lending us the keys to the rides for a test of two twin-plate clutches. Paul's has an OS-Giken in it and it was rather easy to control, partly attributed to the power-assisted clutch in the Skyline. I was half comparing to the standard GT-R clutch, and the RG clutch in the Silvia and it came in about half way. Brett's clutch is an unknown twin at this point, and was pretty much close to a standard feel. All in all the wife was pretty happy with the decision to go the twin plate OS-Giken. Thanks again for all the comments.
Cheers
Brendan
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
