im selling my direct port nitrous kit complete with lines bottle everything needed to fit comes with a full bottle of gas and is jetted to 108hp 6 cyl kit can be used on 4 cyl and rotor aswell
price $950plus freight
ring jason on 0424348521
how easy are these kits to install?
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2797970
  • 1 month later...
hi
is this kit sold yet? where are you located?
is it the direct port fittings that sit under each injector or a fogger tapped into the manifold near each cylinder?
thanks
Justin
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2897928
  • 3 weeks later...
kit comes with 10 pound nitrous bottle
braided main nitrous line
nos solenoid
fuel solenoid
6 seperate direct port foggers with jets
braided lines from solenoids to distribution blocks
and solid lines from distribution block to foggers
kit is complete ready to use
freight will be no probs anywhere in aus or tasmania
new price $800 plus freight
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2938400
600rwhp 15 psi no gas
the reason for sale is the nos was to get the turbo onto boost with a 4500 rpm stall converter as street registered car ran 9.3 @141mph
the new engine runs a methanol motor with a 5200 rpm stall converter and 2 step so no need for the gas anymore
nos was also used to win dyno comps which im also not interested in anymore
Edited by jas/slo32
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2950486
Have left message on your phone and sent pm , please call me - thank you :(
https://www.sau.com.au/forums/topic/149538-sold/#findComment-2953560
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
