Well I started on my rebuild today...with my heart in my mouth...
Unplugged the ecu, took out tail shaft, unbolted it all from the intercooler etc etc,
Tomorrow hopefully it will be out. Then comes the tedious hard part, The rebuild etc...
Anyway, will keep you informed as to how it is all going.
From all the options I have looked at I have decided to build an RB2.2det. Hopefully will take 6 months or so.
Cheers,
Russ
https://www.sau.com.au/forums/topic/14973-started-on-the-rebuild-today/
brackets that need to be made...small things that dont fit cause youre using diffent engine bits...larger injectors, bigger turbo, upgrade gearbox to handle the power, Its always going to be more expensive to build because it is not a standard engine so things will have to be machined more and modified more than if you built a standard engine.
Russ
Have you done it before? Big task to attempt if you haven't but thumbs up for giving it a good go!
But i guess i've started on a reasonable amount of pulling my engine apart, and probably could work out how, just have no reason to. .. its all mostly just bolts after all.
building a 3ltr really isnt that much more,if u use the rb25head u can use things like exaust manifold,maybe the turbo if yourve got like a t04 already, and the bottom end stuff for the rb30 it actually pretty cheap,i prices brand new pistons and chromeoly rings for the rb30et and they came to $400 for the set, (thats through work)
how much power are u looking for out of this rebuild?
cause im looking at doing the exact same thing
yeah, so russ, expanding on what narky said, is the extra .2 mainly done for torque? or power? Any other advantages of increasing the litres?
cheers, and good luck with the rebuild!! I really want to find out how everything all works, etc, so when i get my skyline hopefully i'll be able to do most of the things on the car. Service etc.
extra .2 will give more torque and more power thru more capacity...nothing startling there, also might as well because it is just as easy to do 82mm bore and still undecided as to whether I will use rb20 crank or rb25 crank...they give 2.2 or 2.3 litres respectivly(roughly).
just about to actually remove the engine from the car right now....crosses fingers.
going to try and get the engine and gbox out in one go.
Russ
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
