Hi All,
Testing the waters to see how much interest there is for my car... if i can't get the price that i'm looking for, then i won't sell it... i don't really want to sell, but am toying with the idea of getting a nice sedate cruiser (i.e. not an all-out ball-tearer :D)
Here's a bit of info on the car:
1992 R32 Nissan Skyline GTS-t M-Spec
approx 210000km
Recently had its major service at 197,000km, in which the following items were replaced:
  • Clutch Slave Cylinder
  • Timing Belt (Gates Racing)
  • Idler and Tensioner bearings
  • Water Pump
  • Fuel Lines
  • Fuel Filter
  • Cam Seals
  • Crank Seals
  • All Belts
  • Coolant Flushed
  • Gearbox Oil (Redline Lightweight Shockproof)
  • Differential Oil (Motul Gear300)
Has a reconditioned radiator with new end tanks (reconditioned approx 6 months ago)
Just replaced the rear rack ends and the rear steering arm balljoints
Front tie rod ends were replaced just after major service.
The car is serviced (spark plugs, oil filter, oil) every 5000km
Religiously looked after by conservative/mechanically sympathetic owner (i.e. car gets driven like your grandparents are driving)
The car made 171.3 rwkw on only 11psi boost
Car has run a 1:03:xx on both the Sprint and Sportsman circuits at Queensland Raceway
Car is registered until February 2007
Exterior Mods:
  • Nissan S14a Rims with GoodYear Revspec RS-02 Tyres, in 205/55/16 (tyres approx 50% remaining)
and
  • Nissan R32 GTS-t Rims with Bridgestone RE55s (SR Compound) Tyres, in 225/50/16 (approx 70% remaining)
  • Rear Wing Removed, and Boot Welded Up/Resprayed
  • R32 GTR or GTS-t Type M Sideskirts and Rear Pods
  • R32 GTR Front Grille
  • R32 GTR Aluminium Bonnet
Interior:
  • Nismo Leather Gearknob
  • New Leather Gearstick and Handbrake Boots
  • R32 GTR Steering wheel
  • R32 GTR Drivers Seat
  • Autometer Boost Gauge
  • Impakt's NissanDataScan Consult Interface
  • GReddy Turbo Timer
Suspension & Braking:
  • Kings 'Lows' Springs front and rear (Fitted 26/07/2005)
  • Bilstein Shocks front and rear (as above)
  • Flying Performance Front Strut Brace
  • Generic Rear Strut Brace
  • Whiteline 24mm Front and 22mm Rear, Blade Ajustable swaybars
  • Whiteline Adjustable Front Camber Bushes (Fitted 26/07/2005)
  • Whiteline Adjustable Front Castor Bushes (as above)
  • Whiteline Adjustable Rear Camber Bushes (as above)
  • Whiteline Subframe Lock and Align Kit (as above)
  • Custom made Hicas Lock Bar
  • Ferodo DS2500 brake pads front and rear (only a couple of months old - barely worn)
  • DBA 4000 Slotted Rotors on the front
  • Machined standard Rotors on the rear
  • Motul RBF600 Brake Fluid
Engine:
  • Flying Performance 3" Front/Dump Pipe Combo
  • 3" High-Flow Cat
  • 3" Kakimoto Catback Exhaust (extremely quiet)
  • K&N Pod Filter
  • Custom Heat Shield for Pod Filter
  • Heavy Duty Clutch of Unknown Origin
  • RB25 Turbo with RB20 Actuator (increases base boost)
  • R34 GTT Sidemount Intercooler with Custom Piping
  • GATES Racing strengthened Timing Belt
  • D2 Fuel Pressure Regulator
  • Walbro 255 Litre/Hour Fuel Pump
  • GReddy Type S Plumbback BOV
  • TurboTech Boost Controller set to 11psi
  • Remapped ECU Chip mapped by DrDrift
There's probably a heap of things i've left out, but i can't think of any more at the moment...
if you have any questions, feel free to post them here, and i'll do my best to answer them for you! :(
Here are some pictures of the car from 27.08.2006 (Still looks the same)
as you can see, the car is well looked after, and is probably one of the cleanest around...
and some of the dyno chart:
I'm looking for $18,000 ONO
Car is located in Brisbane
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
