hey guys its usually a simple task i know but ive emptied my master cylinder completely and now i need to rebleed the whole system since installing the r34 brembos and new braided lines. this is a wgnc34 stagea im talking about.
now i have the r32 gtr workshop manual (i only got the jap stagea one so its no use to me) and it shows u need to bleed the abs unit itself, which has 2 nipples on the top of it, but the stagea one doesnt and only has 2 lines on top, so how do i bleed the abs?
obviously the rest is easy and start from the rear left wheel, rear right, front left and front right last.
any ideas on bleeding with the 4 spot brembos which have 2 nipples on each caliper? do i just do the left front wheel first and do the furthest nipple first, then the closer nipple and then the front right in the same order (starting from furthest to closest)???
any info appreciated
https://www.sau.com.au/forums/topic/150058-bleeding-brake-system-abs-unit/
thanks mate but i already have the 32 gtr manual and it doesnt tell u how to bleed the brembos and it says bleed from top of the abs unit nipples in which my stagea doesnt have any and has 2 lines on top of the abs instead that run to the master cylinder.
From memory working on commodores you don't actually have too bleed the abs unit it's done automatically when you bleed all the calipers. You just have to remember when changing your pads not to just push the cyliners back in as it backfeeds the abs unit and f**ks it...Might be the same with the 33's if the units have no bleed nipple on them....
No need to bleed the ABS unit just calipers, and long as you havn't removed or replaced the master you wont even have to bleed that. Its teh same as doing a brake fluid flush, you suck the reseviour dry and just refill it then flush the lines..no need the bleed the master.
If you do run into trouble however you can do a pressure bleed on the master by cracking the lines while you have a helper pump up and hold the pedal.
R33 ABS unit is probably bled with the consult/scan tool electronically
Deren
Edited by Godzilla32
  • Like 1
You just have to remember when changing your pads not to just push the cyliners back in as it backfeeds the abs unit and f**ks it....
So what's the trick to get the pistons back into the calipers safely when ABS is fitted ?
  • 4 years later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
