Coast run today.
a few of us are heading down for the arvo...
meetin at crazy clarks 1.30 for a 2pm depart.
hit the spit for a bit and then cruise up to the espland, etc.
anyone interested is welcome to come along.
we did this a while back and turned out to be a pretty good arvo.
ANYONE THAT HAS A UHF!!! BRING IT ALONG!
https://www.sau.com.au/forums/topic/150326-coast-run-today/
Coast run today.
Is this members only !!!!!
https://www.sau.com.au/forums/topic/150326-coast-run-today/#findComment-2800048
Will be there, but dont think i will make it in an hour. Would you be kind enough to wait for me or put it forward a bit. I only just saw the post. Still have washing and house work to do and wash the car its filthy after the rain
Edited by subzeroR33
https://www.sau.com.au/forums/topic/150326-coast-run-today/#findComment-2800298
Sif do house work wash car and you will have time :D
https://www.sau.com.au/forums/topic/150326-coast-run-today/#findComment-2800335
Yeah i was 3/4 done im finished now. But looks like you guys are gone.
Well if there are any late starters here that want to meet up let me know.
https://www.sau.com.au/forums/topic/150326-coast-run-today/#findComment-2800407
It was quite different not being in my car, I got to hear what each car sounded like and I finally got to see what it went like compared to a skyline (pitifull) but I do know that the panniers slow it down. It was good to meet some new ppl, I wish I met that driver of the grey 33 tho >_<
https://www.sau.com.au/forums/topic/150326-coast-run-today/#findComment-2801306
