hay guys i wanted to know if there was a webstite anway where on the laws on mods in vic state..
i have afew question with mods
i was speaking to afew people and they said you can only have 1 intake mod e.g if ihave a fmic and a cai
i can only have one ?
are we allowed to have these mods if we get engineres certificate?
and what else are these cops ganna pick on =)
cheers
https://www.sau.com.au/forums/topic/15048-laws-on-mods-in-vic/
  • Replies 43
they'll pretty much pick on anything they like
ive heard stories of people getting dicked for not having a H pattern on their gear knob
bov that vents into the atmosphere is a no no
air filter even
bald tires
steering wheel
head lights being too blue (actually being white but they think it looks blue)
no third brake light
the list is endless
and yes you can only have one air intake mod
if you want to have both just chuck the original airbox over the pod
Vicroads vehicle standards information guide is about 30 pages long and can be accessed by clicking here
There is a search function, and you may be able to find what you are after by searching for it, or you may have to go page by page.
Other documents can be found here
http://www.vicroads.vic.gov.au/Home/RulesS...rdsInformaiton/
P.S, I left that last link as the url to point out that VicRoads dont know how to spell "information" :P
Guest INASNT
fark the police/epa man do what u want to your car, infact it is yours and u did pay $$ for it. If u get caught then put it back to normal, then put it all back on after the tests.
I did :D
They wont be picking on imports in about 2-3 months cause bracks pockets will be full of $$ by then. When its emptys he can always got the BS 3km/h speed cameras to rake in more $$
It's not worth the hassle.. some people want to get their car how they want it, and leave it.
They don't want to screw around with changing stuff every time they get pulled over. :D
What a pain.
Just get it how you like it, and leave it!
yer the poice are beyond tight on import cars, i have also heard they are blitzin the import market, that is bein harsh on da imports
some of these rules are kinda dodge though....the air filter one for example, if u have a pod, its illegal but if u put some form of box on it...its legal? meh, i just dont get it
no no no no no!
*sigh*
Pod filters are legal, providing they are paper element filters.
Oiled filters are not EPA legal.
EPA also says that you are only permitted 1 modification on the intake... so apparently if you have a turbo, you aren't meant to have a pod filter.
What a load of..... :bs!:
Guest INASNT
Originally posted by R31 Skyline Chick
no no no no no!
*sigh*
no kylie if your car came with a turbo stock, then u can have 1 intake mod, ie a fmic.
Kylie???
um.. well let me see... pod filter or intercooler...... now.. which one would people choose????
I think most people would prefer to have the intercooler and run an Apexi paper filter pod. ;)
Aftermarket steering wheel is legal providing that the diameter of that wheel is not smaller than 33cm across. My momo race wheel is 35cm across so it's legal. Many aftermarket steering wheels are offerend in two sizes, 32cm & 35cm. The 32s are not legal.
This is based on RTA vehicle modification guide. I dunno about vicroads but I suppose the size standard should be similar. But if you have airbag as standard equipment, you're not allowed to change your steering wheel unless you have written permission from Dept of Transport (or RTA or Vicroads ?) before you do that.
you guys mentioned vic roads rwc? before?
i wanted to ask when my car gets complianced and the enginer comes in etc
if its got an fmic in it which it does exhuast etc cold air intake steering wheel
does he pass it?
and then what happends with rwc do i take it to vic roads
how the hell are they ganna know whats legal and wats not all the poeple that work there are just stupid?
i dont understand? what they look for?
if you want information on the legalities of turbo timers (which aren't legal in Vic :) ) then call the Police station and ask to speak to a TMU member.
watz wrong with a turbo timer??? :D Bloody pigz.......Alwayz c em running red lightz....bastardz..
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
