I posted this in Specific Auto discussion, but i know there are some wise SA people who don't alway check in there so i thought i would try my luck here too.
So i think i have a coil pack problem, i did a quick search through the posts on here and it seems as if this is the go but i thought i would just make sure and ask others if they had the same things happen.
This has only happened to me twice, both in the last month. The first time i had just got out of the drive way and all of a sudden the TCS and SLIP dash lights came on as did the check engine light. The check engine light went off, but TCS and SLIP stayed on. The car still drove fine, so i got where i needed to go and then shut the car off. When i came back to the car i turned it on and it started no problems, but the A/T (Auto/triptronic) light started flashing, it flashed a number of times and then went off. After that i drove the car around no worries then yesterday i got in the car turned it on, reversed down the drive way and as i reached the bottom the TCS and SLIP lights came on again and stayed on, and the check engine light came on and then went off. I drove the car back up the driveway and turned it off. I then turned it straight back on and the A/T light flashed a number of times (16 i think i counted). I turned it off, then back on and it started fine, no warning lights at all.
As i said i think it is a coil pack problem from what i have read, the car is going in for a service Wednesday (in 2 days) so i want to get the problem fixed then. So i'm just making sure this is the problem and that others had the same type things happen to them. Also how did others work out which coil was bad?
*****EDIT******
I ran a Self-Diagnostic and got Error Codes
26 -----Turbo Pressure Senor Signal Circuit: Turbo pressure sensor output voltage is aprox 4.8V or greater open circuit or less than 0.06V closed circuit for a predetermined time.
43----- Throttle Position Sensor Signal Circuit: Throttle position sensor output voltage is aprox 4.7V or greater open circuit or less than 0.06 short circuit for a predetermined time while park/neutral position switch is OFF and vehicle speed is 4 km/h or higher.
So aparantly these are my problems, but i have also heard of people having coil pack problems and the 21 code not showing up and them getting other fault codes instead. Yet when the coils were changed the other issues went away. Has anyone had these fault/error codes on there 34 before?
Cheers
Sean
Edited by mxtcy
Hi Sean,
I know at least on the CA18DE that the warning lights come on when your engine misfires from a coil. Not sure about the RB motor though - is it running really rough when the lights come on? Is it just on idle or when you apply throttle? One way to check, providing it does it on idle, is removing the ornament cover and looking for stray sparks under the coils. If it's doing it on higher rpm's, then you'll probably need a spare coil and replace them one at a time.
Best thing to do from time to time, even if you don't have any coil problems, is to remove the coilpack, clean up the tips for any carbon deposits, then silicone spray the inside of the boot and the coil body.
Hope this helps.
Cheers
Howie
I had the problem myself last week in my 32. We took the ornamental cover off, started the engine (Make sure its cold and problem is present), then one at a time unplug a coil. If the motor goes slugish, then that coil is not the problem. Do it until you unplug one that makes no difference to the idle. Turn off engine, take out the coil and more than likely you'll find it has arc'd out or the like. Had 3 go in mine, wasnt nice :)
It actually sounds to me like your throttle position sensor may be up the creek mate. The TPS is linked into the auto trans & traction control systems so there's a good chance that may be the problem.
I'd be looking at other things first besides the coils if you are not having any problems with the way the engine is running. Does it go ok on full throttle both from low revs & on max boost? If it does I'm a bit doubtfull about it being coils.
The TPS may even just need a slight adjustment.
The turbo overboost could be attributed to the exhaust & front mount if the sensors maximum isn't very high. I'd say it's likely irrelivant to your problem.
Edited by JazzaR33
Yeah could even be just a dodgy connection if it's not faulting all the time. Or if it's the TPS & it's just slightly worn in a couple spots it may play up intermittently.
Will be interested to see what they find
Results are in....
... car is perfect!
Mechanic said its nothing to worry about as he couldn't find anything at all wrong with the car.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
