Put June 21-22 in your diary.
Eastern Creek is having a tin tops day featuring historics.
Nissan will be well represented with 2 GMS R31's and a GMS DR30.
These are the real deal racers in full warpaint. Other cars on the Grp A front are a couple of VL's and a Seton racing Sierra (boo, Hiss)
And if you like the sound of race V8's that sound just like V8 supercars don't, the wing and flare Group C boys will be out in force as well.
Should be HUUUUUUUUGE!
Hooks
  • Replies 40
:P
the hey days of racing.... the swoosh sound from the turbos....
makes me feel young all over again.... but then again I'm not that old.... :confused:
Cheap tickets please. Only for Sunday cause I'm working Sat.
Is this it ??
NSW Car State Open Meeting
Eastern Creek International Raceway
June 21st - 22nd, 2003
Gates open 7.00am
Activity starts 9.00am
ADMISSION:
Adults $16.50
Concession
Aged, Disabled and
Students 13 to 17 years only. $11.00
From here : http://www.eastern-creek-raceway.com/home.htm
If that is it we could all meet at the cricketers arms at 0700 for breakfast... then cruise to EC and park together and have atop day.
I'll have to check if CA does breakfast.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
