Put June 21-22 in your diary.
Eastern Creek is having a tin tops day featuring historics.
Nissan will be well represented with 2 GMS R31's and a GMS DR30.
These are the real deal racers in full warpaint. Other cars on the Grp A front are a couple of VL's and a Seton racing Sierra (boo, Hiss)
And if you like the sound of race V8's that sound just like V8 supercars don't, the wing and flare Group C boys will be out in force as well.
Should be HUUUUUUUUGE!
Hooks
  • Replies 40
:P
the hey days of racing.... the swoosh sound from the turbos....
makes me feel young all over again.... but then again I'm not that old.... :confused:
Cheap tickets please. Only for Sunday cause I'm working Sat.
Is this it ??
NSW Car State Open Meeting
Eastern Creek International Raceway
June 21st - 22nd, 2003
Gates open 7.00am
Activity starts 9.00am
ADMISSION:
Adults $16.50
Concession
Aged, Disabled and
Students 13 to 17 years only. $11.00
From here : http://www.eastern-creek-raceway.com/home.htm
If that is it we could all meet at the cricketers arms at 0700 for breakfast... then cruise to EC and park together and have atop day.
I'll have to check if CA does breakfast.
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
