hey everyone had a stagea for a few months now and found my first problem. under hard acceleration in first gear it hits the limmiter and bogs down then changes to secound. this has only started to happen in the last few days. anyone got any ideas
https://www.sau.com.au/forums/topic/150575-first-gear-holding-in-to-long/
How about investing in a fluid flush at your next trans service? It may be that you have some crap floating around in the bottom of the transmission that is coming up to the valve body under high pressure (read high revs).
If you do it, ask the tech to make sure there are a couple of magnets in the bottom of the trans oil pan. They are valuable for picking up ferrous peices of muck that get into the oil, and it never ceases to amaze me how many people have them removed because they don't think they should be there.
just been for another drive but took it easy (no high revs) and found another problem. on the freeway when it changed to third gear at half revs it started to slip and had to back of to get grip. I think i got an idea of wats wrong , something to do with the bands slipping? thought i would have noticed some symptoms before yesterday though. is this going to be expensive to fix
fluid levels are fine and fluid looks clean, nice and pink. the sliping seems to be getting worse and seems to be in third. droped her of cos shes due for a service to keep my waranty and there going to check it out for me... hope its not the tourqe converter ( not covered in warranty ). gotta love that warranty got me splitfire coilpacks for free. yay...
they told me it is, or feels like the clutch packs and first and third share the same pack so thats why i mainly noticed it in third and not first. That warranty is comin in handy. covers up to 2000 and im getting them to do my valvebody while there at it :)
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
