Seen these before? Easily remapped? Anyone even got one? ~800 for a trade in ur stock ecu for one of these sounds ok...
http://www.mines-wave.com/english/products...cpu-nissan.html
I asked Mine's and they said this is only part they hold for ECR33's. They are still alive and kicking.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/
I dont know where you get $800 from, but you need to check your exchange rate. 96,000 yen is just over $1000 plus shipping of your ecu there, plus weeks wait while they send one back, plus the shipping back. It would be over $1200. plus it's just a re-map of a standard ecu. you could do it here for less (hell you get buy a power FC for less) and at least whatever you did here would be tailored to your car and aus conditions.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805344
There must be some benefit though. I mean you pay ~800 (because I did conversion... dont make this an argument about conv rates its about vx-rom.) and you trade in your ECU for this one, it has to be something better than just be a Mine's part.
Do you pay the amount just for a re-mapped ECU and a Mine's sticker on it? I sent another email to Mines to give me all the features about the ECU. They got back to me within 2 hours last time so well see.
I got to say I'm a big fan of Mine's tuning, they do a fantastic job on their cars.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805389
go ahead and buy it, but i can tell you, it's just a remapped standard ecu with speed limit removed, rev limit raised, fuel cut removed and mapping suitable for higher boost. and yes the price is relevant to this thread. 96,000 yen is over $1000AUD plus you have to pay for shipping both ways and do without an ECU for a few weeks. a power FC for instance which is readily tuneable can be had for around $1000 AND you still have your old ecu so no time spent off the road, and when you swap you can sell your old ECU for say $150. Total cost then is $850 + tuning.
I also think mines are a great tuning company, but buying a pre-tuned ecu from another country, from a tuner that has never seen your car is not a smart idea. taking your car to mines and getting them to map a chip for you in real time on the other hand would be great. if you lived in japan that is.
and FTR I have previously used a mines ecu in one of my cars.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805660
^^ his right mate. i also love the mines tunning shop & their work. but honestly better to get a power fc and get it locally tuned. i sold my power fc that came with my car because it wasnt tuned and i didnt have the money to tune it at the time so i bought a mines ecu. i 100% regret doing that hahaha. dont get me wrong the mines ecu is good for bolt ons (exhaust air filter etc), but once u start doing injectors/afm etc u'll need something that is re-tuneable.
https://www.sau.com.au/forums/topic/150744-mines-vx-rom/#findComment-2805810
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
