Why Is The Sun Red When The Smoke Is Grey?
I was having a bit of a family discussion today, and now im wondering...why is the sun red or bright orange when the bushfire smoke is grey? Shouldnt the sun just be..well grey and not as bright as usual? why orange?
Is there some scientific explanation for this?
Does anyone know?
its the light refracting through the smoke. Its the particles in the smoke that make it look orange.
^^ he used bigger words than me
So no point me trying
big words?? ill remember for any future posts i make to use small words :):P
Edited by akeenan
big words?? ill remember for any future posts i make to use small words :laugh::)
lol :ninja:
refracting... i could give you a laymans explanation only, and it would probably 50 words to describe that one :sorcerer:
Well, I asked God and he said, "its because no one wants a grey sun". Then we had an in depth discussion about the Egyptian god of the sun Ra and how he really isn't pulling his weight these days. He also told me that my pet rabbits had to die on boxing day many years ago because they were developing into a super intelligent species of evil rabbit overlords hell bent on the destruction of life as we know it and it was messing with his poker night. But that's another story. oh and what "mister big words" said also has some merit within the scientific community
I would have thought it was _similar_ reason to why sunsets are red but not truely the same reason.
There would be less light coming thorugh the smoke therefore it appears red, not yellow/white as the sun does.
Basically, the light is defused through the smoke.
Fair enough but where does the RED or orange actually come from? the smoke is grey...it somehow contains RED or orange particles??
Maybe we just put it down to some sort of phenomenon?
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
