Hey guys,
Is it hard work to lower an r32 by yourself (cut the springs). Would i need to do anything else if i were to do this. I only want it lowered 1-2inches. The wide tyres wont allow anymore.
What needs to be done?
If it would be too hard, how much would it cost to get done properly with smaller springs? and where is a good place to take it? Im on the northside of Brisbane.
Thanks,
https://www.sau.com.au/forums/topic/15098-lowering-r32/
anythings possible for the right price!!!
I have a lowered 32 and my shocks in the rear are rooted!!!!! Back Left especially!
Need to change asap, all the fluid has sprayed out everywhere!
Very uncomfortable to drive.
Save yourself some heart-ache and do the best suss work you can, it is worth it!
https://www.sau.com.au/forums/topic/15098-lowering-r32/#findComment-307219
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
