Hi Guys,
Had my car on the dyno today getting my pfc tuned. Asked the mechanic if we could run it on 12 psi.
This afternoon when I went and picked it up he said that he could not get any more than 9psi. He said that he thinks one of the waste gates was stuck open, does this sound right. It's a 32 gtr with standard turbos and a manual boost controller. Chris
https://www.sau.com.au/forums/topic/151108-boost-problem/
A stuck wastegate will stop you running higher boost for sure but if your mechanic/tuner can't ascertain the nature of the fault then you might want to consider taking it somewhere else. A good mechanic/tuner is worth his/her weight in gold, especially when talking boost.
Have you ever been able to run more than 9? Does it have a stock computer (My 33 GTR has the stock boost restrictor in place but was running 13psi - found it had an aftermarket computer).
2nd opinion can never hurt, try to find someone who knows Imports and particularly GTR's.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812727
THANKS it has a power fc, i got a feeling he put the boost controler on the wrong line no matter how much you ajust it still the same boost.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812793
Did you install the PowerFC? Are you sure there's not a boost control module for the PFC installed somewhere?
It does sound like he's doing something wrong though, you should be able to vary boost by 'some' amount if it's on the right line. I've not fitted a controller to my GTR (only had it a week) but on my Series II GTS25T it was installed on the vacuum line between the Intercooler pipe work and the Wastegate actuator. Make sure it's installed the right way too, if it's not it will boost all over the place and you'll be picking up RB26 pieces =\
Edited by ActionDan
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812853
yeh i put the pfc in but it's the same with the standard one.may have to start pulling shit off and have a bit more of a look.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812884
I'd be getting a second opinion before you start ripping it apart. Try to find a reputable tuner/mechanic with Import/GTR experience. Explain the situation to him so he can inspect the wastegates and go from there.
Good luck, let us know how you go :huh:
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2812913
The issue of safe boost level on stock ceramic GTR turbo's is a contentious one. Many people have safely run about a bar with no issues, many others have reported turbo failures and in some cases engine damage from ceramic dust being ingested. The decision is yours but be warned that pushing the ceramic turbo's WILL reduce their life and increase the risk of failure as does pushing any component harder.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813078
yep i wanted to run at about 12.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2813135
Doesn't the power FC have its own ebc therefore eliminating the need for the manual one? I got my car tuned to 13 psi and i had the power fc and eboost hooked up. The eboost was controlling the boost levels but when i went to pick the car up the engine light was on. The mechanic said "oh that just happens to skylines with the power fc" which i didnt take kindly since i entrusted my car to him. I came on here "SAU" and found out that the power fc has a boost controller that u can turn off with the hand controller. I did that and BAM! engine light gone...
In all maybe the power fc boost controller and manual boost controller are crossing paths and playing with your boost level? Perhaps disconnect one and see if theres any difference.
Matt
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2814610
Matt
maybe he has put the boost controller on the wrong hose.if i was looking in my engine bay what hose should the boost controller be on?at the moment it's on a small hose under the intake.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815546
Matt
The PowerFC Boost control is a separate part you purchase (the solenoid).
Its the same thing that the Apexi ACV-R uses.
So you need to actually purchase the solenoid separate, and then install it.
It doesnt come with the PowerFC itself
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815554
na i dont have pfc boost controller just one of those GFB ones.
https://www.sau.com.au/forums/topic/151108-boost-problem/#findComment-2815581
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
