Hay guys i just bougt my car got system installed today =) very happy its abit of extra weight and i think i can feel it alittle =)
but i guess thats what happends =)
well here is my consern when i brake on the right hand side front wheel it sorta makes this scraping noise not hard just like kuurrrrr
and it happens somtimes and somtimes it dosnt.
this happend really bad in my other car but the break was actually worn to the metal in one part so iam not sure stressing out abit
the noise only happens sometimes then comes back and then goes away at other times.
on the rwc it says 80% the break pads but iam not sure
could it be abs. i know forsure its only on the front right wheel?
any suggestions? =)
also are the breaks hard to change on the 180sx and how much am i looking at spending for a normal decent pair of breaks =)
Thanks guys =)
  • 11 months later...
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
