mobil 1 does seem to go off.. i have checked my oil a few times since last service and it's been sweet, only a light brown colour and didn't look like it had used any... then i checked the other day and it's below the low mark :uhh: and also turned quite dark. only just 8000km since last service on a pulsar, so even on an NA car I'd be changing it at 5000km intervals in future or be very careful about checking your oil regularly :P
https://www.sau.com.au/forums/topic/15146-which-oil/#findComment-309258
i run motul 300v 15w-50 in my r32gtr and we run 6100 10w-40 in our shop 180sx - used to run mobil 1 but found eng oil pressure reduced over time - motul maintains its viscosity longer - importantly change the oil often i do it every 5000k and also change the filter remember oil is the engines life blood
https://www.sau.com.au/forums/topic/15146-which-oil/#findComment-310028
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
