For $90,000 seems a bit over priced although some decent photos might heap. Engine shots, brake setup, wheels, in daylight , in focus etc.
I'm also thinking of purchasing a v35 and was wondering more about how hard parts are to get.
It has the same engine as the 350z so for servicing/repairs can parts be bought from nissan?
Also with the ones that come with the tv screen, anyone know how hard it is to convert it to work here?
ya, exatcly how similer it to the 350Z...interms of sharing platforms / engine and so forth......
i just joined this forum. i have a 2006 350GT manual coupe arriving in March to NZ. They look awesome with kits. goto www.g35driver.com and look at the Picture Share forum, or view the thread called "Hot G Summer Pics" -Mike
The V35's are a different class of car to it's predecessors. They may still share the Skyline name, but where as the previous series skyines were turbo animals with a roaring straight 6, overall the V35 is more refined and more of a larger sports touring cruiser type car. The engine being of larger capacity is torquey and smooth, and the car overall is quite large and solid. IMO they're really nice, but, like I've said they're in a different class compared to the older model Skylines.
It comes down to what you want out of a car, and how much you're willing to spend on it.
v35s are awesome vehicles and to my knowledge there are 11 different models. Thanks to nissan fast many of the parts are easy to get hold of and are shared with other vehicles in the nissan range.
The V35 is indeed in a different class and a great progression if you ask me (or any other v35 owner).
Some of them can look very plain in stock form (in paticular the 250/300 4 doors) but with some bigger rims/ kit the car transforms. I was lucky enough to get the factory aero bodykit otherwise I was going for the wald kit (fantastic kit and now available in brisbane).
Also, any parts that fit a g35 will fit a v35 (which can help when looking for some performance parts).
But there are plenty of aftermarket performance parts available from japan...you just have to search (which is half the fun). My next purchase will be some tein coilovers for my gt-8.
As for the TV...I've searched and searched and I keep getting told it can't be done. Though I recently heard about some local guy who has vision through the screen but I'm not sure if its the stock tv but I'll be checking it next week. You can get the screen to play a picture but you require a box from the states that converts the nav connection to rcas.
I've got a dvd headunit and just went through this process
Edited by kleenbeats
SO....can you use the DVD navigation system here with AUS maps or we can not
I don't think so.
I meet the same problem Want to use GPS in AUs with the JAP GPS unit on. But i Failed.
The audio guy give me w options:
1, Install a VDO unit in the "up-grovebox",and use the Stock screen to display, use the remote to control.
That cost me 1700, Consider I already get a TOM TOM G710 for $900, I just drop the option.
2, Install a DVD player in the "ip-grovebox", use the screen to display DVD film. ETC, that also need a lot of work because the screen seems in RGB input. That cost me about $800 with a S**T Brand unit.
I think this is what kleenbeats DID.
The result is : I give up.
What I am trying to do IS: Disconnect the TV unit , Used it harness to get a set of AV input.
Does any have any experience on that or anyone can get the Harness Manual for the audio syetem???
Please help me.
I Guess every one are looking for this things.
Edited by Frank350GT
I don't think so.
Please help me.
Give international motor group on parramatta road in Sydney a call. They advertise in Unique Cars as well if you need the phone number. I bought mine off them over a year ago and they said they would have the TV and NAV all sorted in a couple of months. So based on that conversation they should have had a working version for almost a year.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
