  • Replies 41
While we're on the topic of 300 rwkw neo engines, i also have a 25det Neo engine with 310 rwkw on 18 psi boost. However the power isn't coming on as strong as i'd like it. My tuner says he can get it to come on harder but he's worried about the engine as he hasn't had much experience with the neo engine. Don't have a dyno graph to show you but basically the turbo kicks in at around 4000 rpm and rather than a sharp jump and easing to 300kw, it's basically a straight line building up to it. It felt quicker when i had it tuned for 250 kw due to the majority of the power coming in between 4000-5000rpm.
Question is, is there really that much concern bringing it on harder, apart from the expected wheelspin?
Mods:
600 hp turbo
650cc sard injectors
greddy intake plenum with q45 90mm throttle body
600*300*75 hybrid intercooler
Pod filter
Splitfire coilpacks
microtech ltx12-s ecu
Stock RB25DET Neo engine
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
