i've got a full house RB26 with
HKS 25/40 turbos,
full decked head intake and exhaust
HKS 700cc injectors
Nismo adjustable fuel reg
Split fire coils
Apexi camshafts 280
Apexi head gasket
SS Valves
Pistons
Rods
Crank
N1 Water + Oil pump
with front LSD
All work was done in japan, egine came across as is with car.. i've spent plenty of $$$ on detailing and extra performance bits
Came from my R32 GTR which was written off, got hit in the back..
Located in Sydney, $25K now $20K or make an offer
0433 384 056 DAYTIME
pics are posted
Edited by WLD_GTR
https://www.sau.com.au/forums/topic/151712-full-house-rb26-turbos/
Mate i understand and thanks for the heads up, But here u get the quality and reliability of full house workshop engine from japan.. also $25k is just a starter i did mention to Make An Offer, but i shall drop the asking price too.. thanks
Sorry i dont noe wat crank, rods, or pistons are in there.. but iam guessing from the apexi head gasket and camshafts that it would be all apexi.. iam not to sure on how much kms since it was built or who built it.. as i previously said that i purchased the car from japan and the motor was already in it. So as i previously said it is a complete built engine from a workshop in japan. You cant go wrong with the quality and reliability from a japanese workshop. Also with the HKS 25/40 turbos already bolted on. No it is not an N1 block
Edited by WLD_GTR
Japanese workshops are just like Aussie ones...there are good and bad...for all you know it could be a STD bottom end with bolt on's done on the grass under a tarp beside his lean-to. Some REAL facts and information about the product your selling would be a good start. 2540 turbo's have been out of production for a few years now and yours look a bit tired. It could have been built more than 5 years ago and possibly has plenty of klms on it. A realistic price would be a good start too....possibly even less than half your current price may find you a buyer.
  • 1 month later...
ill offer u $6000 IF it passes compression? you can keep the turbos...... and ill come pickup today?
That's a great offer. I'd consider taking it if I was you.
My mates R32 GTR made 450 kw at all 4 on the Autosalon dyno with a big single. :rofl: He thought it had a built bottom end even a storker. Some time later the engine spun a bearing from cracking a oil pump.
He was devstated and happy at the same time finally opening his engine and seeing the bottom end was totally standard. But he was happy to have produced 750-800bhp with standard pistons and rods. :)
Just shows what an amazing CRD tune can do :P
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
