Hi,
I have a few items for sale.
1. MV Automatics Manual Valve Body
Item was purchased through MV, installed but the project has been abandonned, its in perfect working order, complete and ready to install. To suit R32, R33, Z32 automatic box's (RE4R01A, RE4R03A)
No pics at this stage (it looks like a regular valve body, the magic is on the inside.)
2. MV Automatics Solonoid Shift Controller
Shift Controller
3. VG30DET T3 BB Turbo
This turbo was taken from a low km VG30DET front cut I purchased. The cut had 40,000 km's (digital dash) and the turbo is really clean.
pic1
pic2
pic3
pic4
pic5
pic6
4. T3 - T25/T28 adapter - less than 40mm thick
I had this made to put a T28 onto my stock FJ20 exhaust manifold, but would suit many many other applications. I had it custom made at Bushell Engineering in brisbane. It sealed perfectly and never gave me any trouble.
At only 40mm thick it will suit alot of cars, other adapters available do the same thing however are ALOT thicker, and not as strong. It will allow you to install a well sized internally gated T2x turbo onto your RB20/25.
pic1
pic2
pic3
pic4
pic5
Prices.
MV Valve Body $250 (was $350 from memory)
MV Solonoid Controller $200 (was $300ish from memory)
VG30 Turbo $400 ono
T3-T28 Adapter $120 ono.
Thanks
I can be contacted via mobile, MSN or email.
ph. 0419 172 032
email : [email protected]
Edited by tim510
https://www.sau.com.au/forums/topic/151715-garage-sale/
just wandering, this is not the shift kit for an auto is it? once this valve body is installed the auto must be shifted manually right?
interested just not clear on whether this is the shift kit or not or is this suitable for a daily driver skyline.
https://www.sau.com.au/forums/topic/151715-garage-sale/#findComment-2826023
oh and is installing like installing a "regualar" valve body?
have a read of this.
http://www.skylinesaustralia.com/forums/in...l=mv+automatics
the valve body allows the stock auto ecu to controll the solonoids, or u can run the lock up box for a more aggressive shift.
have a read of this. this is a for sale thread, not a technical one sorry
Edited by tim510
https://www.sau.com.au/forums/topic/151715-garage-sale/#findComment-2826162
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
