hey guys,
thinking about doing a small photoshoot soon and would love to get 4 great examples of skylines together
preferably a black r31, r32, r33 and r34 all together would be best and would make one/some awsome photo/photos
if you have a black 32-34 and would be keen on this soon could u post up ure interest and we can try and work something out (ie date and place etc)
if we cant get all black then maybe all white or all red skylines together would be good
thanks for any interest, would be a bit of fun and will get pics printed in the end aswell and hand u each out a copy if u would like
oh and i would be taking the pics but u are more than welcome to take ure own aswell!
cheers,
Lorenz
https://www.sau.com.au/forums/topic/151881-skyline-photoshoot-r31-r34/
so is this a day where we all come and we can like all park neer the same colour's then just go round taking shots of grouped cars hopefully say..
Gunmetal Grey
32, 33, 34
Red
32, 33, 34 , dont think 32 was red but hey and so on
and within the different models have like
GTSt, GTS4, GTR and
2door 4door depending on how much interest you can get
was hoping to just get 1 example of each skyline (ie r31, r32 etc), so have like 4 cars alltogether thats all, and preferably all of the same colour if we can organise that
in the end id like to end up with a nice shot of a 31, 32, 33 and 34 all parked next to each other to show the change over the years of the skyline
could make a nice poster, banner or just a nice photo for both ure self, my self and the site
ive got a black 33, wide body.......spent some cash and made it look pretty nice and unique
what the f**k is a steel girder doing sticking out of your front bar? LMAO THAST f**kING HUGE...
sweeet
thanks Nightcrawler, Nathan_G1, FORZA-MOTORSPORT and Ron
i got a black (well black over silver) import 4 door so thats the 31 sorted or ill get my mates all black 2 door 31 (both of which were on the end of year SAU cruise)
http://lorenzproductions.com/lorenzVideo/P...09.06%20002.jpg
all black 4 doors would be awsome as :yes: or even all black 2 doors, either way its cool with me
cheers 4 the interest guys, didnt expect so many replies so quickly!
hey ron mate, didnt realise u had a 33 already, be keen as to see u there
now i just need to organise a date and time and place and were set!
wat time and day suites most people best?
lol.. dream on :yes:
one thing u could do.. go get a BRAND NEW black paint job next week JUST for the photoshoot and u can be in it then :( sounds like a good deal i reckon!!
haha kdn, ure more than welcome along, but mainly wanna focus on the group of cars id like to as stated :D
lol g0t contact :yes: ill covewr my car ready for back to school
yeah will prolly come cause i know a photoshoot of all cars will happend even just to post on the site not for the intended purposes of banner you wantng to do :(
glad ure keen evan, u dont have much choice ne ways haha :yes:
if i can get all 4 skyline models in same coloured groups then ill shoot them 4 sure
getting 1 complete group is the main aim but wat eva else we do is cool with me 2
prolly meet up on scotland road just off railway trc in mile end, perfect spot to meet and shoot some pics, ive shot a few other cars there b4 and theyve come out a treat :(
r31 coupe shoot:
tims coupe shoot:
bens coupe shoot:
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
