hi guyz
have an r32 gts4.. this morning started the car put the aircon on so it would be cool 4 when i jump in.
Start driving and notice my speedo isnt reading, hasnt moved from 0. Then my steering starts getting really tight like the power steering has stopped, after bout 10mins the hicas light comes on.
Turn off the car, turn it back on, steering is fine again, drive for 100m and it starts again.
So i checked all the fluids, power steering fluid in engine bay is fine, rear reservoir in the boot is fine.
Check power steering belt to see if it hasnt broken and thats fine too.
So ive decided to disconnect battery overnite and see wat happens in the morning.
Now for the speedo, does any1 have a clue wats happened?? everything else on the dash cluster is workin except the speedo and the odometer of course coz that works with it.
is the speedo electronic based or cable??
any ideas wat 2 do with both issues???
thanks joe
https://www.sau.com.au/forums/topic/152023-weird-problem/
either your speedo cable has broken, the square drive for the speedo on the end of the cable is worn, the cable has come undone from the gear box or fallen off the back of the dash. check them all out. i'm sure that the hicas and powersteering need a reading from the speedo to work.
on mine the square drive wore out, my speedo stopped working. my hicas light come on and the power steering stopped working. changed the cable and it was all sorted out. cost about $90 brand new from nissan. easy to change aswell.
i have seen a thred out there on how to change it. do a search.
https://www.sau.com.au/forums/topic/152023-weird-problem/#findComment-2831325
yea its cable driven. there is a sensor on the back of your speedo that adjusts the strength of the power steering vs the speed you are travelling at. from what you say, it sounds like the cable has snapped. its just a matter of getting a new cable (nissan sells them for around $100) pull out the dash board. follow the cable from there to the gearbox and replace it. easy fix to all of the probs
https://www.sau.com.au/forums/topic/152023-weird-problem/#findComment-2837705
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
