I gots an 93 32 gtst still pretty stock, just a pod filter and bleed valve
its done 135kw with 12psi on croydons dyno this week a new Cooler and turbo back exhaust is coming what kinda gains can i expect in regards to power output and 1/4 mile times ive been told 180kw is possible. can anyone shed some light on this..
cheers...
https://www.sau.com.au/forums/topic/15217-r32-power-gains/
115rwkw on a DD Dyno I made stock. Timing fiddle etc I made around 125rwkw. on stock boost.
Then exhaust and 12psi boost I made 152rwkw.
Then the turbo starts to hit a wall of efficiency so to speak and 15psi only picked up power to 164rwkw.
Also If you get the ecu tuned etc and run a bleed valve that will drop boost to around 12psi you will make 160rwkw. So .. with an ebc and tuned ecu with 15psi and You may make around 170rwkw.
This is on a DD Dyno I'm not sure about Croydens.. Every dyno reads different :)
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-310393
joel when you say tuned ecu do you mean to upgrade the stock item or replace it all together. Also with all the rain last night i got a little (lot) drift happy, reckons i thrashed it a bit too much, mainly in second gear now it bounces on idle down as low as 400rpm but then it sits right after bout 12 to 15 seconds any ideas ???
im gettin worried i broke something.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-310687
With the R32's you can re-program the standard ECU.
I'm not sure if any one can do it in your area however.
It bounces on idle down low... mine bounces in first and second when putting around a car park when labouring the motor at 400rpm is that what you mean???
When I finished up work to go to uni I sat on the rev limiter in first clicked second second creeping up the road on the rev limiter and broke nothing. Can't imagine thrashing a car more than that. :)
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-310737
it bounces with the clutch in i was hoping after its little rest last night it would have come to its senses and started behaving again but it still doing it i havent really noticed any power loss
The reason im worried about it is cause i've been pretty ham fisted with it lately guess i'll have to get the mech to look at it
BTW did you have to make any ecu changes once u put your bosh fuel pump in & did ya notice any change???
cheers
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-311952
If i give the car a hard time the clutch seems to shudder a little just as I start to let it out. That is normal Just glazing of the flywheel I guess. Not really sure but it returns back to normal if you give it a rest :P Nothing to worry about my old mans 5yr old Landcruiser does the same thing with a 3month old clutch in it.
With regards to the fuel pump...
With the stock fuel pump at 12psi I wasn't leaning out it was still running slightly rich.
I slapped it on the dyno to boost it up to 1 bar and also fitted the bosh fuel pump. OMG did it run rich! Way to rich. Went down on power big time.
It lost mid range power and running 1 bar was around the same as running 11-12psi with the stock fuel pump. However I ran a fuel pressure bleed kit from RPM which helped lean it out a little but still not enough up top.
If i have the AF's perfect up top the mid range leans out up to 5500rpm and pings.. which is not good.
It also felt like it lost a bit of power when first coming on to boost but oh well Until a slightly bigger turbo goes On i'm not going to be doing the ECU so it can wait.
Still quicker than those 255LS1 Maloo Manual Utes so I'm happy with it at the moment as not much apart from other boosted skylines and the od' boosted suby (which there isn't many around) beats it.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-312007
If you are making around 160-170rwkw and have extremly grippy tyres there is no reason why you shouldn't be able to run a mid to high 13 to a low 14.
Realistically a Flat 14 is probably more the go. You will know what I mean about wheel spin as soon as you start running 1 bar of boost.
180rwkw will only be possible with a R33 RB25DET Turbo and a tuned ECU, bigger fuel pump etc.. Push it to 17psi and you may even get a little more but on 17psi I would make sure it isn't pinging and you don't hammer it to hard like track work etc otherwise the heat will get in to the turbo and the exhaust wheel will seperate from its shaft.
I've been running 16psi on the standard R32 turbo for quite some time now however the car is only used for 0-100 runs maybe a bit of third but hardly ever.
On hot days 35+ degree's I drop boost down to around 13psi just to be safe.
I've had it running like this for around 60,000km's and it is only now starting to puff a bit of smoke when the turbo is cold as the seals are getting nacked.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-312017
Make sure u do it on a dyno however and make sure its not leaning out. You fuel pump may not be as good as mine was.
At 12psi I was making 152rwkw and that was with it using a fuel pressure reg bleed kit to lean it out. I've noticed that yours is making around that at 12psi so it is possible that your fuel pump won't handle the extra fuel required for 1 bar of boost.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-312432
I don't think that is the latest Zoom..
They used a GT 2530 Turbo and it was Tilbrooks nephew in a White R31 Wagon.
Same RB20DET????
I'm leaning towards the R33 Turbo as after having a VG30BB turbo on my car for a few days I didn't like how it made full boost at around 4000rpm+. Boost developed very slowly.
I think it comes down to if you use old tech turbo's this is to be expected as they arn't as efficient as the new turbo's.
But 180-190rwkw in a R32 is like having 200-210rwkw in a R33 it will be plenty quick for the street. :D
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-313020
I made 125rwkw with the following mods: 10psi boost, 3 dump pipe from the turbo and a 3 inch highflow cat, 3.5 inch cat back zorst, pod filter and the timing advanced to 20deg. How are you guys pulling 150rwrk and what not, just curios. There must something wrong aye?
Plus i also ran a 14.6 with 225 kuhmo's.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-313048
Same RB20DET????
Joel, Have you seen the latest Zoom? What you're referring to happened yonks ago.
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-313236
In Zoom No.52 this is how they got a r31 rb20det to 220kw@wheels
ENGINE : stock rb20det - $1200
TURBO : second-hand HKS GT2530 - $1400
INTERCOOLER : R33 GT-R - $900
PIPES, HOSES and CLAMPS : Aluminium - $650
EXHAUST MANIFOLD : stock - $0
INDUCTION : airbox with K&N filter - $99
BOOST : 1.1 bar, manual bleed - $120
INLET MANIFOLD : ASE throttle body conversion - $550
FUEL SYSTEM : Bosch Motorsport fuel pump, stock injectors, adjustable regulator - $545
MANAGEMENT : Reprogrammed Nissan ECU (chip & dyno time) - $735
EXHAUST : Second-hand 3-inch system, GTR cat, Hiper muffler - $700
RESULT : 220kw@wheels - $6900
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-313326
DLuded.. That exactly the same mag I've got that I had last year.
They also had another mag prior to that one stating how they used to Piazo cores welded them together etc...
Then they released mag 52 that made 220rwkw with less boost 17psi I think and the GTR core.
What is the mag number blind_elk?
Maybe they are re-using story's :O
https://www.sau.com.au/forums/topic/15217-r32-power-gains/#findComment-313518
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
