hi
my stagea is up for sale, it has served its purpose as a family car for the last 2 years and now it is time to move on.
it has the factory leather option, climate control, rb25det, auto..... all the factory options. 80K kms
other mods include full bodykit (but still subtle enough not to draw the unwanted attention of anyone), r34gtt rims, kenwood tv/dvd touch screen, 3" exhaust, pillar mounted boost and volts, full paging alarm with built in turbo timer and remote start.
$19500 neg
this car has been serviced every 5000kms with castrol edge and replaced spark plugs with ngk iridium 5000kms ago. the car is in immaculate condition for a 98 model
i am in no hurry to sell / trade this just seeing if there is interest about as i have plans to complete r34 gtr conversion if i don't get something else i like.
i have only included one pic but more are available on request
thanks brad
Any chance you would be interested in a straight swap with this and covering cost for transport? (tall order I know but never hurts to ask)
http://www.skylinesaustralia.com/forums/in...howtopic=150933
https://www.sau.com.au/forums/topic/152403-98-stagea-rs4-v/#findComment-2847321
  • 3 weeks later...
from the engine bay pics the crank angle sensor is same as the ones found in neo engines
might be same engine as the 40th anniversary r33 sII (very last r33s) which has NEO spec engine parts
crank angle sensor and cams use different key
might help your sale?
good luck with it anyways
https://www.sau.com.au/forums/topic/152403-98-stagea-rs4-v/#findComment-3024769
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
