Hi Guys,
I'm wondering if anyone has any good recommendations as a tow vehicle to tow a car that weighs about 1500 kgs and will occasionally be used to tow a car that weighs about 1650kg. I'm looking for something not more than 10 years old. I was thinking of an AU Ford because it has a 4.0L six and it is very torquey and has a 2300kg towing capacity. I was told by a mechanic that the gearbox can't cope with heavy towwing though. Anyone had any experience towing with these cars?
If not does anyone else have any other suggestions?
thanks,
Omar
https://www.sau.com.au/forums/topic/152531-best-tow-vehicle/
  • Replies 45
Hi Guys,
thanks,
Omar
You will find turbo diesel 4W Drives are the best for towing but they weigh much more than 1500kg .
Your mecahnic would be semi correct.
The problem with the AU falcons, is the gearbox overheats even under normal driving.
If you do an oil change on most autos, usually, the oil will be a dark brown even after quite a few ks. On the AU falcons, the box oil is always pitch black.
Just because the oil is black doesn't mean that it's bad for a tow car. I mean honestly, how often do you plan on towing the car?
They are a very powerful, torquey tow car (not as much as a diesel), but for a petrol sedan, that's about as good as you can get.
I use it to tow my boat, probably every weekend during summer. It goes fine.
If you're worried, add a tranny cooler
VQ-VS stato
Any old V8 ute
85' onwards Patrols and Landcruisers
Basically more torque the better... Large capacity is what you want. Turbo diesels are good... If you are on a tight budget there are people using VN-VP commodores without too much hassle.
Trailer design plays a big part as there can be 100's of kg's weight difference between 2 trailers that do the same job. Also it is ideal to have 80kg of downward pressure on the tow ball when the trailer is fully laiden.
tranny cooler could be done cheap as with some ingenuity..
Thanks for all the opinions guys, I have thought about the diesel 4x4 option but to stay around my $10k budget I would have to be looking at a fairly old vehicle or one with very high kms. Also I think the ford would be comfortable than a 4x4 on longer trips.
Would a transmission cooler ensure the Ford Gearbox a long and healthy life? I've also considered a Lexus LS400/Toyota Celsior. Has anyone had any experience towing with these? I hear there not that torquey for a V8.
hey you can pick up Holden Jackaroo's late 95-96 for around 9k. Both the Petrol 3.2lt and diesel 3.0lt intercooled turbo are great for towing, We have the v6 version, tows great. just a little heavy on fuel, but it is also 4wd and plenty of space for other shit. Easiest 4wd to drive also, for the size!
i'd say something like an old V8. my father-in-law used to tow his caravan to wintersun every year with a VB commodore with a stock 253 in it, and it towed it better than his EA falcon.
although a late model car will tow better than an early falcon. we towed a silvia back from brissy with an auto vt commodore (v6 with over 200,000ks on the clock) and it towed fine, so i'd say an au falcon would be fine. just stick on a good tranny cooler.
but idealy a turbo diesel would be best.
Mitsubishi Delica Spacegear
2.8 Intercooled turbo engine - Plenty of tourqe and also easy on fuel..
Inside so roomy you can get lost in there
Jap Spec - Exeed version - lot of toys - dual sun roof, A/c , rotating reclining seats...bla bla
Low Km Jap imports compared to aussie vehicles for about 10K - 11K Limit
ohh..its a 4*4 - Dhakar Rally winning Mitsu Tech....from the pajero...
AU gearboxes have issues... as mentioned previously.
We had a 92 EB series 2 XR8 manual that we used to tow the boat.... Handled it no worries - cheap car to buy and plenty of grunt. Sold ours for $3K - it needed a respray as do most old red cars! Can pick up a good quality one for under $5K.
Just from my own experience of fitting towbars for a few years, all of the above mentioned vehicles would be fine for towing. Although, Ford has always been rated as a better tow vehicle to holden... much better pulling strentgh. As mentioned, a diesel 4 wheel drive would be an excellent tow vehicle, but may not be in your price range.
AU gearboxes were known to have heat issues with heavy duty towing - this would be the likes of large live-in caravans and large horse floats.
Many towbar fitters would fit transmission coolers when fitting towbars to these vehicles, and this would resolve this issue very easily and cheaply.
Therefore, towing a car and car trailer behind an AU falcon would not be a problem, with a transmission cooler fitted as a precaution.
This is just an opinion.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
