Why would you want to remove carbon canister? Its your fuel tank breather...
The carbon canister is filled with active charcoal to absorb evaporative gases produced in the fuel tank. These absorbed gases are then delivered to the intake manifold by manifold vacuum for combustion purposes.
Edited by pavel
When i had my turbo done in my car and new cooler piping and all that crap my workshop removed the carbon canister... i dun know why they did it but they seem to think it doesn't do anything in particular.. it wont hurt leaving it in, they just took that out and put my oil catch tank there... still not sure exactly what its for tho...
My understanding is that the carbon canistor is your fuel tank breather/removes fumes from the tank when its being filled up or when the fuel is being used (driving). it recirculates into the plenum under vaccum and burns off.
I just pulled the hoses off, removed the canister and blocked the metal lines off with rubber plugs, then fitted a longer piece of hose to the fuel tank breather and ran that to the front of the car.
Runs fine :)
Don`t get caught without it by police or R.T.A. They would take a dim view of it I`m sure.The fumes from your tank will store in the charcoal powder within the cannister where it will be consumed by the engine under vacume.It has no side effects on the performance of the engine at all unlike hot oil fumes from the valve covers.If you let the fumes run to atmosphere then congratu
lations,your wasting fuel vapours and poisoning us all for no apparent reason.By the way,try taking it off and tap it on the ground a couple of times then give it a shake.If you can hear the granules inside then good,if not then it needs replacing as they are supposed to only last 40,000km.
Edited by skylinecouple
Yeah, where do tubes and stuff go. I'm removing this soon as it will be more effort to keep than remove with the new plenum. Anyone know where that one metal tube goes? as far as I can see it leads down the passanger side rail up and over the motor and then down under the drivers side well.
has anyone got any pics of how they blocked the tubes etc
its not as hard as you must think. you pull the ends off at the canister, shove whatever you like down the vaccum line and put it back on. Be careful as there maybe some residue that comes out of the lines.
why not just Relocate it and stay legal, rather than remove and be epa defectable.
thats what i would do.. well actually i belive mine has been relocated to the back of the engine bay cause it looks like someone has crated a bracket for it so they could install a pod filter..
just move it to a better location... :pirate:
If you let the fumes run to atmosphere then congratulations,your wasting fuel vapours and poisoning us all for no apparent reason.
Actually congratulate Brad @ Chasers for that one :pirate: cos when i went back to ask for it.... they couldn't find it nemore... took it all of 6hrs to dissapear lol
But if you want to stay safe with the epa why would anyone own the cars like we do? No one keeps theirs stock and they'll always find something to drill you with... so if your in it to mod you might aswell not do it half heartedly but if it makes no diff in removing it then its no use, might aswell just leave it in.. not that i can talk lol
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
