Why would you want to remove carbon canister? Its your fuel tank breather...
The carbon canister is filled with active charcoal to absorb evaporative gases produced in the fuel tank. These absorbed gases are then delivered to the intake manifold by manifold vacuum for combustion purposes.
Edited by pavel
When i had my turbo done in my car and new cooler piping and all that crap my workshop removed the carbon canister... i dun know why they did it but they seem to think it doesn't do anything in particular.. it wont hurt leaving it in, they just took that out and put my oil catch tank there... still not sure exactly what its for tho...
My understanding is that the carbon canistor is your fuel tank breather/removes fumes from the tank when its being filled up or when the fuel is being used (driving). it recirculates into the plenum under vaccum and burns off.
I just pulled the hoses off, removed the canister and blocked the metal lines off with rubber plugs, then fitted a longer piece of hose to the fuel tank breather and ran that to the front of the car.
Runs fine :)
Don`t get caught without it by police or R.T.A. They would take a dim view of it I`m sure.The fumes from your tank will store in the charcoal powder within the cannister where it will be consumed by the engine under vacume.It has no side effects on the performance of the engine at all unlike hot oil fumes from the valve covers.If you let the fumes run to atmosphere then congratu
lations,your wasting fuel vapours and poisoning us all for no apparent reason.By the way,try taking it off and tap it on the ground a couple of times then give it a shake.If you can hear the granules inside then good,if not then it needs replacing as they are supposed to only last 40,000km.
Edited by skylinecouple
Yeah, where do tubes and stuff go. I'm removing this soon as it will be more effort to keep than remove with the new plenum. Anyone know where that one metal tube goes? as far as I can see it leads down the passanger side rail up and over the motor and then down under the drivers side well.
has anyone got any pics of how they blocked the tubes etc
its not as hard as you must think. you pull the ends off at the canister, shove whatever you like down the vaccum line and put it back on. Be careful as there maybe some residue that comes out of the lines.
why not just Relocate it and stay legal, rather than remove and be epa defectable.
thats what i would do.. well actually i belive mine has been relocated to the back of the engine bay cause it looks like someone has crated a bracket for it so they could install a pod filter..
just move it to a better location... :pirate:
If you let the fumes run to atmosphere then congratulations,your wasting fuel vapours and poisoning us all for no apparent reason.
Actually congratulate Brad @ Chasers for that one :pirate: cos when i went back to ask for it.... they couldn't find it nemore... took it all of 6hrs to dissapear lol
But if you want to stay safe with the epa why would anyone own the cars like we do? No one keeps theirs stock and they'll always find something to drill you with... so if your in it to mod you might aswell not do it half heartedly but if it makes no diff in removing it then its no use, might aswell just leave it in.. not that i can talk lol
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
