Time to get some funds to keep modding. A few things are up for sale.
1. Apexi AVC-R
Installed in ute currently, worked flawlessly, comes with almost everything (except box) minor scratches to unit (a little buff wouldn't hurt)
$400 posted
2. Exhaust manifold and dump to suit 3RZ Hilux
Exhaust manifold, and about 2 meters of exhaust from dump pipe to gearbox crossmember
Exhaust manifold designed for Nissan turbo. Was running a VG30DET high flow, but will work with anything off a R32/R33 T3 turbo. Dump is HPC Coated
(if you want a turbo, i can organize one)
$700 posted
3. RZN149 Petrol Radiator
Kept my turbo 3RZ relatively cool. Would be a nice upgrade for anyone who needs slightly bigger. Removed since have gone bigger (for new bigger hotter turbo)
Recently rodded to be cleaned out. No damage, comes with stock hilux mounts.
$200 posted
4. Turbosmart Vee-Type BOV
Slight damage to adjustment device, but aesthetic damage. Works fine.
$100 posted
5. GFB Mach1 BOV
Comes with plumb back fitting, plumback spring, as well as the mach1 trumpet and spring. As well as GFB Sticker
$120 posted
6. Intercooler
approximate core size is 650x300x55 has 2.5" and 3" inlet/outlet comes with ADRAD bar and plate core. Can cut down inlet/outlet pipes to make shipping easier.
$150 posted
7. GFB Bleed Valve
typical bleed valve
$50 posted
8. Aircon kit for Hilux (3RZ Petrol)
Comes with compressor (may need to be rebuilt) new exchanger, new dryer, most lines (i think im missing one), and cabin exchanger (may come with box)
$600 posted
I am negotiable, but will ignore stupidly low bids. Pickup available.
I will post pictures up tonite, i have some on my server already.
Some items are still installed on car but easily removed.
I am willing to trade on some items, i am looking for:
EBC (other then the AVC-R)
600x300x100 intercooler or similar
3RZ-FE engine, must be rebuildable condition
Edited by -==L=a=N=c=E==-
https://www.sau.com.au/forums/topic/152811-lances-cleanout-sale/
hey, if you dont mind me asking, but what feature do you need that the avcr will not do?.. im tossing up on avcr or greddy profec 01.. and this is the cheapest avcr ive seen.. im also on the coast..
ohh, any pix of the Intercooler?, any piping?
Edited by seriesII
G'day,
AVC-R is good at what it does, but the hours upon hours of fiddling to get it running right is annoying me, especially everytime i change something minor. I used an eBoost before this, and i want the eBoost simplicity back again (3 settings).
I have set the price as to not get those annoying PM's about "will you do it for $xxx shipped" It is the cheapest one around 2nd hand. And therefore price is FIRM.
No piping for intercooler. Pix are above.
AVC-R Sold
GFB BOV - Sold
3rz Exhaust+Dump - Pending Sold
New item added.
600x300x100 Intercooler - bought it but doesn't fit.
Never been used.
$220 posted
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
