Hi Guys,
Planning to get the hicas locked out on my car, from what i've been told seems likes theres two options to go for (short of removing the whole system).
Just wondering whats better to get, just one of those standard hicas lock bars that seem pretty easy to source and work for most cars, or the tomei hicas lock kit, with the electronic module and the shims.
any info would be much appreciated.
Cheers,
Dave.
https://www.sau.com.au/forums/topic/152920-r32-gtr-hicas-lock-question/
The Tomei kit adds weight, but gets rid of hicas pretty effectively. Using the lockbar you can remove ~30kg of deadweight.
Warning light issue can be solved by cutting the sender wire on the hicas computer.
Lock bar is also the cheaper option I'm fairly sure.
http://www.skylinesaustralia.com/forums/in...showtopic=93183
Do that ^^^^^ , with the warning light i pulled the light out of the dash if u are unconfindent about cutting wires
ok but i'm a bit of a noob, don't exactly have the time or the facilities to do ti myself, who can i get to do it for me??
OMG! 30KG! I am doing the bar for sure!
personally I went the tomei kit for a couple of reasons.
1. hicas had not bothered me too much. the odd uneasy feeling from the rear was sometimes off putting, but I dont think it was slowing me down too much either on or off track.
2. with that in mind I wanted something easily reversible.
3. it's neat
4. it's cheap
5. it's easy to install
6. no dash warning
7. no heavy steering
8. no fear of busted PS pump
as far as I could see the advantages of a lock bar vs tomei kit were.
1. decent weight saving.
2. ummm that's it.
so after weighing that up, the tomei kit was for me. it works fine. but lock bar is a good solution too IF done well.
i ripped it all out, ill say now its not 30 kg, ill weight it one of these days
Spoke with Ant Scali before I did mine and from memory it was a 26Kg saving on his 32R
Ok, so where to get it done, and how much would I be looking at?
Depends on where you live, If it was on the West coast I could help a brother out but i'm guessing your on the east sieeed so ??
Price... a couple of hours for an experienced hand plus sorting out the power steering pump + the lock bar ..dont know if GTRgeoff is fabing them at the moment. Cheap considering the results.
6. no dash warning
I agree that the Tomei kit is an easier solution, but these 3 points are very easy to avoid when using a lockbar.
6. Cut the sender wire from the hicas computer. Green with white trace line in bottom left hand corner of the smaller plug.
7. Heavy steering is caused by people leaving solenoids plugged in. I had someone come to me complaining about heavy steering, unplugged the solenoid and the problem was gone.
8. PS pumps only get busted when people block the lines off. The rear stage of the pump is trying to pump fluid that has no where to go.
I wrote a DIY on it a while ago, and have done it on 3 cars without a single problem.
http://www.nissansilvia.com/forums/index.p...howtopic=185697
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
