How rude , can we just get normal sau stickers? , do you still own a r32 ben??
Refer to above post about stickers old boy and "technically" I still own a 32 but it doesn't include an R in its name :ph34r:
  • 3 weeks later...
haha. seen a few skylines about lately. A R33 from memory, cant remember, but it was black with a front lip that used to be blue and is now black. If that makes sense. It also had dark tint. Looked pretty good none the less. It was in a carpark, i won't say where though.
spotto !!! r33 custom plates ( not sure if a can post plate numbers on here ) maroone / burgandy ? in exeter trying to race me then once i back off he flow past then pulled up in a hurry some nast black smoke from exhaust i did see :(
( sorry couldnt stop if ur reading this but was late to drop my car off lol )
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
