Although one been more accurate than the other, could someone refer to me why they are extremely different in values?? and what would xxx amount in dynologic refer to yyy amount in dyno dynamics shoot6f
Cheers guys
Adam
https://www.sau.com.au/forums/topic/153057-dynodynamics-vs-dynologic/
Cheers guys
Adam
Its the dyno operator...we tune at Croydon Racing in Sydney (dynodynamics) ...and at Autosalon (dynolog)the next day made 1kw less power. Both these dyno are ran by very skilled operators...hence the accurate power readings.
  • 9 months later...
Having owned and used both the Dynologic and Mainline Dynos, as well as used countless other dynos, I would have to rate the DynoLog Software (common to both DynoLogic & Mainline) the best I have ever used. The software, data logging, speed control (even tacho based speed control for autos), makes DynoLog hands down FTW.
DynoLog software, originally designed as cutting edge engine dyno software, has been modified to run as a chassis dyno. With as many inputs as you could possibly imagine, and data analysis that would satisfy the most data hungry scientist.
The differences in all the power outputs come down to a few factors, the main being atmospheric compensation (mainly AT on DD). Dyno Log dynos use their own discreet weather station, constantly sampling atmospheric pressure, temperature, and humidity. Dyno Dynamics dynos sample air temp from the probe, which is placed under the bonnet or other high them areas by some operators, hence 'inflating' dyno figures. Atmospheric pressure and humidity are a 'user' input, and are certainly not updated automatically, let alone real time.
One other major variation is the SAE standards used to calculate atmospheric correction. The older standard J607 is still found to be used on many dynos, and in general can read around 3-10% higher that the newer SAE standard J1349, which is what is used by most newer DynoLog dynos, and also on the Mainline/DynoLogic dynos used for the AutoSalon series.
That I think, is the difference in Dyno Dynamics (dyno for mechanics) and Mainline/Dyno Logic (dyno for technicians) Dynos.
Apart from the above atmospheric corrections, there are other 'intentional cheating' methods employed by less honest, or less educated, dyno operators, such as roller intertia values, and other rudimentary calculations...
If anyone would like to discuss my opinions, or needs some contacts with either Mainline or Dyno Logic, please do not hesitate to call.
Sam.
0425 818 755
Edited by Dr_Drift
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
