  • Replies 103
Anyone heading down this sunday if the weather is good? Aidwin made noises about trying out his new turbo..
Zanda and I were thinking of a dams cruise in the morning followed by some drag action at Kwinana. Weather permitting of course..
rob its all in the clutch.
and of course a reasonable set of tyres, pineapple do help also
let your street tyres down a little dont completely fry them in a burnout they actually go off if over heated. and make sure if you drive through the water you turn the tyres before staging. it will take a few runs to get it right
but just get a feel of when it rolls away then into it.
Ok, if enough people are going I might go again. But can someone give me a hand tightening up my pineapples? I should have tightened them up when steve had it on the hoist at SST when he did the dump pipe, any offers? At least if I can get them tightened I can come down with you guys and get some tips on what I am doing wrong :D
This is what I am thinking too... I had them tightened to the torque setting by a mate and they came loose, so speedworks tightened them up again to the setting and they came loose so this time I am tightening them till they are squashed and wont come loose again. I got the whiteline kit same as rev210 and he's tightened the **** out of them and had no problems.
the two at the front are generally tightened with a hose clamp, if you have cut them to fit through instead of removing the subframe enough to slot them in
if they are cut ... and you aren't using anything to hold them together ... then it is an extremely didgy setup as even though they have the pressure from the subframe / weight of car, they can still snap out
there shouldn't be any torque setting, just tighten them to shit
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
