Hi guys,
Almost at my wits end trying to rectify my boost problems now. What i need is someone who has installed a AVCR boost controller (or similar - i have instructions now - woohoo!) and a few hours of thier time over the weekend. I'll shout a carton of their choice for the favour.
Basically for those who don't know, my car had an exhaust leak in december, i had that rectified by the awesome guys down at Belconnen Discount Tyre Service (Marc2 and co), however since i've had it back, its suffering a severe lack of boost problem.
Mechanically its fine - purr's like a kitten, no misfires, clean airfilter etc etc etc.
I have a feeling that something to do with the AVCR isn't hooked up properly. Jayce put me onto Glen at ESP however he can't get to look at the thing till after monday. Glen mentioned that the most common thing that goes on is that people don't hook up the Comm point on the Apexi solenoid to the Turbo's Actuator. I'm going to be honest here and say, i have nfi where the actuator is :P
Failing that if someone could go through the install with me to check its all where it should be, and hopefully all the problems go away.
So yeah, if anyone can help me, throw a reply here and i'll pm you my mobile number :P
Thanks in advance guys.
https://www.sau.com.au/forums/topic/153140-need-a-favour/
This might sound silly, but have you checked your cat at all? I found that mine had the insides collapse into this awesome mess of cloggingness which stuffed my boost right up. New cat and off I went though - might be worth a look.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848796
no rattles or anything that would suggest it. Not to mention the fact it would have to be hideously coincidental.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848973
The actuator is the round half beer can shaped goldie coloured metal canister just above your turbo {I'll try to find a pic and show you}. It has an arm coming out the back of it that controls your wastegate.
What Glen means is that your AVCR is your boost controller and its not get the boost readings. In the engine bay there should be a part of the AVCR that has little 6mm rubber hoses coming out of it. One of these hoses will be hanging loose, you need to plug it back into your actuator. It will have a nipple coming off it for a hose to push over.
Atm your AVCR is not reading boost, it is reading atmosphere.
Of cause this is only any good to you if that is the problem, and I don't know why Glen did not fix it for you on the spot, it is a 30 second job.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2848999
Glen was on the phone, he's out of town till monday.
What i've got is
2 hoses out of the Apexi Solenoid going to their proper places (so i'm told - which is why i'd like to check), can't remember anything else coming out of them.
However i do have the standard solenoid there, but the hose out of it is blocked off with a screw.
i'll try and take pictures tonight and show.
The AVCR is reading boost (as well as the standard boost gauge) it just slams at 0.55 kg/mm rather than heading all the way up to 0.8 like the controller is set to allow it to.
I have SOME boost, just nowhere near what i should and what its set to. What will the wastegate do on its own?
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2849017
Nothing,
1. It is prob. not getting enough boost to open.
2. It is driven by the actuator which is getting no signal [maybe if hose is missing?].
Where was your exhaust leak? Did they play around with the turbo/manifold/dump pipe area - which one?
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2849880
Nothing,
3 headstubs and manifold gasket all gone, required a head doctor.
Will look at that spot in a few.
Thanks heaps mate.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2850883
yeah if your running a ceramic honey comb filter
but if you have a descent stainless steel after market cat with a stainless steel filter you shouldnt have this problem.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851018
A picture speaks a thousand words...
SO
here be a picture of the apexi solenoid.
These aren't around the wrong way are they?
here's the other angle
Now the other (original?) solenoid that has the blocked off pipe, wtf? the other one goes to this other pipe which i suppose is internally venting something somewhere.
Finally an overhead shot hopefully showing everything.
I'll take my camera to work, so if you need any more pictures let me know.
Thanks once again guys, and remember if we can't fix it via a forum, i'll put a carton of your choice in your pocket if i can come around and have someone show me whats wrong.
Cheers,
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851933
So on the way to work this morning, i went via the monaro. Some REALLY wierd shit is happening now. I have a distinct suspicion the AVCR has forgotten its settings.
Sitting in 4th at 100km/h off boost, plant your foot it rockets to 7k rpm, then falters back to 5.5k rpm and goes forward as you'd expect it to.
Its almost as if the clutch was held in (maybe i need a new clutch, but that would be a coincidence as well.)
Boost still wouldn't budge above 0.65.
Any chance it could be this stupid hot weather we've been having? not to mention its a nice chilly temp this morning?
Edited by nsanity
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2851960
That old solenoid and tubing could all be binned [i think] its not doing anything. Just block off/seal the holes in the pipes.
I'm not sure about the apexi solenoid and the hose positions, you need the instruction manual to see if they are hooked up right way round [i've got a Hks unit and its different obviously].
Otherwise all you hoses ect look right to me.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852004
Unfortunatly i know little about EBC's but my Manual bleed valve is setup as such
Inlet pipe hose into bleed valve then it comes out the other end and goes straight into actuator which is what it looks like yours does. The only other thing i noticed is your lines are not really that direct i was always told with boost stuff to make them as short and straight as possible.
As tridentt also said you dont need the stock two stage boost controller any more just make sure any possible leak is blocked off but if it wasent you would probably hear a hissing sound/ idle problems.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852005
Ckeck if your actuator arm to the wastegate is OK and not loose.
Try cleaning your AFM, don't touch it, just use brake cleaner or carb cleaner and squirt it heaps. I wouldn't have the afm plug sitting up like that, rotate it so that the plug is level or facing down a bit it stops moisture etc sitting there and getting into the afm box.
Otherwise my remote help abilities are all worn out.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2852012
hhaha, dead clutch.
its in at the shop again :)
thanks for the offer widebody
Saw your car in the shop today. I went in to see Marc about a wheel alignment for my Chaser, also to look at his wreck. nasty stuff that is.
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2854796
Problems all solved yesterday, thanks to the guys at Autotech.
Would have gone to ESP on Jayce's recommendations, but he didn't give me the number! :woot:
Its all better though - i missed her.
I did too get the number to you...only two days late,LOL!!
Car sorted?
https://www.sau.com.au/forums/topic/153140-need-a-favour/#findComment-2892684
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
