Here's the story
I want to get a blow off valve for my car (Stock r33gtsts1) and have seen a
few good ones on the forum,
but a friend of mine recently told me not get one
unless its plump back
she got a r33 s1 gtst as well, and when she had her bov
she had to keep her car revved up otherwise it would stall
i thought it was possibly to big, but she said it was just a standard
turbosmart bov
so here's the question, does it have to be plump back?
cheers
https://www.sau.com.au/forums/topic/153195-blow-off-valves/
doesnt' have to be plumback although if ur only after cosmetics like sound etc etc then yeah atmospheric bovs sound better for performance wise i'd suggest stickin with a stock one
i have an aftermarket hks ssqv in ma gtt sounds sweet as and i think they are startin to make kits for the ssqv's now to make them plumback
https://www.sau.com.au/forums/topic/153195-blow-off-valves/#findComment-2850395
Here's the story
turbosmart bov
cheers
It doesnt have to be plumb back but being plumb back will prevent possible stalling issues?
https://www.sau.com.au/forums/topic/153195-blow-off-valves/#findComment-2850405
If you have a AFM orientated car, then you need a plumb back full stop.
Do I even need to explain it? AFM Measures the air, and then your stupid Vent to atmosphere BOV wastes that measured air when it is not supposed to.
Engine thinks air is going in, so it adds fue. Fuel gets there, and the only half the air does. (cause the other half went out the BOV) and the car stalls.
Put the factory one on and stop trying to be a show off.
https://www.sau.com.au/forums/topic/153195-blow-off-valves/#findComment-2851075
Can't say i totally agree, as in i have a atmospheric bov along with a lot of people on this forum and my car does not stall. a lot of the turbosmart atmo bov's like mine (stage 2) have an adjustable spring rate by turning the head of the bov, by doing this you can achive the correct spring compression which will keep the bov closed during idle and hence not stall. I agree that the afm has measured a certain amount of air which is then changed by the bov when it vents and hence the afr's are out of wak a times during shifts but you can still run one on your car without dramas. I have had my stage 2 for about 6 months works fine. Also have one on an s15 and no problems either.
https://www.sau.com.au/forums/topic/153195-blow-off-valves/#findComment-2851237
harsh... if he wants one he can have one...
https://www.sau.com.au/forums/topic/153195-blow-off-valves/#findComment-2851265
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
